Hi everyone,
It's been a while and things have been somewhat getting back to normal lately. I've been moving along with the run, but ran into a snag with the cnc mill I'm using at work to finish them off. The Z axis (up and down) was losing steps and losing it's zero position. After every descending and retracting operation, the Z was physically +1 while the digital readout showed it correctly at 0. During the drilling of the holes for the bullets, I didn't notice since it goes straight through the material and the Z height is not critical.
When I started the fluting, that's where this gremlin showed it's face. It got to a point where it was milling the flute and breaking through to the underlying holes it sits between. Being the mill I use at work, this is a major issue since any other parts made would be useless. Luckily we're not busy at work and this is usually the time we do general machine maintenance on all our machines before things get crazy.
I've replaced just about everything short of replacing the whole machine. Stepper motor was changed out to a Servo, new driver, new interface board (communication between controller and machine), new controller PC and checked and repaired any issue I found with the mechanical side of things (backlash, bearings, etc). This issue will be resolved this week. Being the shop mill, there is nothing left for us to do to see if it's an easy fix and have a technician coming on Tuesday to see what we missed.
I know it's been a long time running, but I'm doing what I can to get this all done a wrapped up. I want to thank everyone for their patients with this train wreck of a run.
