Thanks for that recognition, I lost track of this thread and just now saw your post.Also-- this is the thread that inspired me to make the guide.
Thank you LOM, I’m glad to finally tidy up this thread so it could help someone in the future.Pick your favorites
Resin Stunt (MoM tour): MoM Resin Cast - Google Drive
Shared Stunt/V3: V3 Pictures (Updated 8/29/20) - Google Drive
And for the Yuma/ISYHANL/Cave Build: Magic of Myth ( MoM ) Luke RotJ Hero ( cave build ) lightsaber research, images, reference, & collaborative model builder's discussion.
(none of these images are mine so no credit needed!)
Added the pics and a loose representation of what we can classify it as.There’s the resin shared stunt (resin V3) which was posted earlier but isn’t listed in the first post. It can clearly be seen when Luke climbs the side of the sail barge.
Pic from earlier:
Better pic:
Edit: wanted to clarify, these are either different casts of the V3 or the nipple was removable as it can clearly be seen on screen, but not in the promo shot.
Slight correction - I believe both of these are cast from the V3 rather than the V2 (See: clamp holes on the WIRED saber pic)R2 fired resin Stunt (sail barge scenes)
[ Resin cast of shared stunt/ V2 origin ]
Climbing resin Stunt (Sail barge scenes)
[ Resin cast of shared stunt/ V2 origin with emitter tip ]
I’m happy to omit V2 Provenance from the climbing saber description, however I don’t think there is enough info. on the R2 saber to tell exactly which saber it was a cast of between the V2 & shared stunt.Slight correction - I believe both of these are cast from the V3 rather than the V2 (See: clamp holes on the WIRED saber pic)
I too believe this to be the case, but thought my labels were clear enough to imply that was the case. I’ll see what I can come up with to clarify while remaining concise.Yuma/ isyhcanl/ cave hero are proven as the same base. Based on everything I’ve seen 100% sure and the box itself too.
Yuma/ isyhcanl/ cave hero are proven as the same base. Based on everything I’ve seen 100% sure and the box itself too modified from the Yuma through to the cave build
I’ll drop the v2 from the R2 saber lineage.The R2 saber is missing the nipple and from the pics I’ve seen doesn’t have the longer V2 lever, since these features were present on the V2 in ANH I think we can safely say it’s a V3 casting or at least wasn’t a V2 casting.
Can you post a pic other than the one in the op to support your claim? Are you asserting that the climbing and the R2 saber are one and the same? I suppose the emitter nipple could have been removed for clearance of R2’s dome door.
edit: was typing while you posted Dewy
I’m not down with the “V3” talk so I’d prefer to continue calling it the shared stunt, which is clearer, and more traditional.
