acidicninja
Risu, the shifting layer happens when a stepper (usually the x it seems on da vincis) isn't getting enough current. Either up the current in the firmware if you're using repetier (which you should be, btw) or slow down the print. Slic3r allows for pretty specific speed settings. Also DO NOT UPGRADE THE FIRMWARE if you're using the arduino cartridge hack. Honestly I don't think the arduino method is worth the bother though. I did it for a bit and it was so finnicky that I just installed the repetier firmware and ***** tap dancing ****** does it make a difference. You really have no idea what you're missing out on until you do it, and it's extremely simple to do. No hardware mods, no messing with programming an arduino, don't even have to make any physical contact with the printer to do it. If you guys are interested I can put up a guide here on how I did it pretty easily.
