This post has taken me many hours to compile. As it cover a lot of ground I ask that you take your time to read it thoroughly & consider carefully before making any reply.
Having spent many hours tracking down the video & posts casually mentioned on this thread relating to what Brandon says about the V2 I’m including them here for everyones edification.
The video is this one: Star Wars Celebration 2015: Original Luke Return of the Jedi Lightsaber Reveal
Published on Apr 23, 2015
The posts are on this thread:
Luke ROTJ V2 lightsaber
Brandon’s posts are:
#668 pg 34 ; #698 pg36 & #703 pg35
& yes I went through all 54 pages.
So what does he
actually say?
Well in the video (app 1.12 min) he does say that when he took it appart he could see where the motor went & how the systems works but doesn’t give any specifics or show any pictures. At app 2.39 he discuses the emitter & says the entire emitter rotates & that when the blade spun the emitter was spinning as well. That’s all he says on the matter in the video, all well & good as 2015 goes,
however…
he writes more in his posts.
His 1st 29th Apr 2015 is mainly about his doubts as the V2 being cast but has this on the motor;
“The saber contains a chamber where the motor once was, and you can see the threaded holes where it mounted. “
Although, as there is no motor, how can we be sure what was in there. I agreed it is most likely a motor but there is always a residual doubt.
His next is 30th Apr. the 1st part is again about cast or not but has this on the emitter;
“The emitter head spins freely. It is secured (by two allen screws at the end) to an internal rod that runs down into the chamber where the motor was.
At this point the rod's only purpose is holding the emitter on. At one point a rod would have run from here to the motor, and I imagine both the emitter and blade were secured to it. There is gaffer's tape over the joint where the emitter connects to the main body, theoretically to prevent it from spinning (probably added for ROJ.)”
The part I’ve highlighted in italics shows the rod currently has no other purpose. The part I highlighted in bold is conjecture the words ‘i imagine’ are a bit of a giveaway.
His last & most interesting is also on the 30th Apr – it deals almost exclusively with the emitter & describes how it is now;
“The nipple is part of the whole emitter unit. There's a hole in the end of the nipple, and in that hole fits a rod that is secured at the other end of the piece (in the motor chamber.) The two allen screws on either side of the nipple thread into a groove that runs around the end of the rod, and then the whole emitter spins around the rod.”
The nipple & emitter are one piece. The nipple has hole in it containing the rod that secures it to the body & the emitter spins
around the rod &
not with it. Clearly from this arrangement the V2 can’t take a blade. There is nothing in any of this that is a clear indication that the V2 emitter
as it is now bears any relation to how it as in ANH.
Also, clearly, Brandon wasn’t aware of the evidence we have just brought to light of a static emitter on screen., at last I hope that’s the case.
This isn’t all – oh no…
We now have a problem linking the V2 to ANH at all.
In the vid, Brandon uses this screen capture to show the ‘short nut’ of the graflex clamp.
It’s OB1’s salute before vanishing. 3 problems this. Again I understand Brandon is unlikely to have known any of what follows.
1) it’s difficult tell if that’s what we can see.
Kurtyboy has kindly made these 2 screen shots for me to help see. The 1st is from the noise reduced version the 2nd is directly from the direct film scan. Neither really improve things much but I’m prepared to go with balance of probability towards yes it’s a short nut.
noise reduced
scan
2)This is the same shot Kurtyboy has as a short video above, & from this point
there are 5 consecutive frames clearly showing a mark on the emitter that remains still. So if you accept the attribution of the clamp as indicating this is V2 you also have to accept it shows a static emitter.
3) The most damaging - Brandon’s assumption of the uniqueness of the long lever/short nut clamp.
From post 2 onwards in this thread :
ANH Jawa Stunt ION Blaster / Alternate Blasters RESEARCH THREAD
We have a short nut graflex clamp on a different prop. The speculation on this thread is that there is a long lever on the other side – which is pure conjecture & that this particular clamp finds its way onto the V2 – again pure conjecture, for all we know they had a box full of short nut clamps.
Even if this conjecture is true there’s nothing to stop that clamp making a stop off call on a different motorised V2 type hilt in between.
I view of all this new evidence it’s very difficult to support the premise that the V2 in ANH (assuming it is the V2) had a emitter that spins, there is not one shred of credible evidence for this & some clear evidence that in at least 2 shots in the duel the emitter is static.
For what it’s worth my call on this is that it is the V2 in ANH, or rather the V2 from the neck down, there is this shot of a motorised V2 type hilt with a long lever clamp (which Brandon also uses in his the video)
There is evidence of something being housed in the body of the V2 which was most likely a motor. That in the alleged rush to get a ‘new’ hero prop for ROTJ that the blade holding emitter assembly, which I suspect may have contained a bearing, has hacksawed off, going through the drive shaft too, so the motor could be quickly extracted & a new ‘solid’ emitter machined & attached to a new static rod. This fits all the evidence, with the one loose thread of that pesky other prop sporting a short nut clamp.
Again I understand that in 2015 Brandon would probably have been unaware of all the new evidence that has emerged recently. Maybe someone should make him aware of it now?
