Mouse Vader
Thanks for sharing your theories. Let's go easy on Brandon. He owns the darned thing and has done extensive work documenting these films. He can't share everything, nor does he have to.
There is obviously a gap in our V2 knowledge about the nipple. Either Brandon was mistaken or we are, and the nipple/plate are one unit. The nipple was sort-of a collar to raise the anchor of a blade and make it more secure. Other versions of this do exist, some stunt blades apparently contain collars at the bottom as well, and I think these are all the same experimental type of system. I'm still digging around myself trying to figure some of this out in other threads. If it was part of the emitter, it would explain the set screws underneath the emitter rim, much like Anakin Starkiller's latest V2 run.
The little-block clamp being on another prop is not damaging evidence. I've said it a few times before, pieces of props got swapped around, and there is little to show they had multiples of weird parts unless they are cast greeblies (blasters).
Looking at the emitter plate, I can guess strongly that it is the V2. I just don't see why the emitter couldn't have just come loose or skipped under the set screws, leaving it stationary. These things were faulty.
I'm glad you took so much time going through everything, a lot of us have been on this ride a while, and its smart to build on or evolve the work thats already been done. If we threw out conjecture without analyzing it these threads would be very short and very few new ideas would come to light.
I posted at 12.36am it took you app.45min to find, read & compose your reply.
Well constructed & considered criticisms only please not hurried pat put downs & half baked, contradictory patronisation please, however politely put. I expected better from you.
It’s also not unthinkable that there were more then one clamp with that missing lever piece. There was just a Vintage Graflex on eBay not long ago with that same missing piece.
I
Useful info, thanks. A possible inherent weakness, though not severe enough to be common?.
As I point out If you are relying on such a features uniqueness to link the V2 to ANH, when that uniqueness disappears so does the certainty of your link. Fortunately there is the picture of a motorised V2 type with the long lever which currently is unique (but uniqueness is never guaranteed as we've just found out). Unfortunately it's a still, so no help on the emitter spin front.
Without the motor what keeps the rod from sliding out
In Brandon's post # 703 he merely states :
There's a hole in the end of the nipple, and in that hole fits a rod that is secured at the other end of the piece (in the motor chamber.)[my emphasis]
So secured some how but he doesn't say exactly how.
,and Brandon has shared some things but
We should pay close attention to what he has shared too. In post #703 he gives a clear description of how the emitter & nipple are now. If you listen to the video I linked to, from 0.23 he makes it clear that in ROTJ a different prop was used when a bladed shot/action was required & we can see from B's description that the V2 currently can't take a blade & that what is present now are replacement parts - presumably for ROTJ.
I believe he made a mistake to presume that these replacement parts some how bear a relation to what was formerly present, and my belief is based on the new static emitter evidence, so I see how he gets to where he got. (OMG is B fallible like the rest of us mortals?)
As Kurtyboy has just pointed out (yet again) there is zero positive evidence for a powered spinning emitter, there are 2 positive pieces* of evidence for it being static. The balance of probability has shifted, there's no dishonor or weakness in changing one's view to fit new evidence, it's how science & research are meant to work. Human nature, unfortunately, is to cling to what you know.
* three pieces - I'd forgotten about his stickman clip.
&in a previous post that obi one would hold his thumb on the emitter to slow the speed down.
These are arguments are known in debates as 'appeals to special reasons (or circumstance)'. They have limited value, which is that they are plausible, but sad to say are generally regarded as desperate measures to keep afloat a sinking ship & multiple uses (esp the same one used more than once applied to hypothetical mechanisms, thd9791) only make matters worse. Plausible does not equate to probable.
I am now completely lost when it comes to how it is together today
Understandable. Too many conjectures & misquotes will do that. Clearing some of the fog was one of my primary aims in my post #217. B's #703 post is quite clear on the emitter arrangement - if in doubt refer back to it. Try and avoid appeals to special reasons.
As Mentioned elsewhere B owns the 'damn thing'* - he's also taken it to bits, so what he has shared has to be taken as primary source material. Keep it at the top of your thinking.
*woops misquote should read 'darned thing' - sooo easy to do I know.
