Pyramidrep
The model parts I knew we’re on their way.You mean the white parts or the detailed squares in the pics?
Mmmh...and the mystery thickens, but wow...I mean WOWThe model parts I knew we’re on their way. The image is the shock.
Well I guess not everything got thrown into a dumpster in 1981. I guess it’s an “open secret” in Hollywood circles just to torture nerds like me.
There you go.
I’m gonna lie down for a while.
Yep. Things of beauty indeed. Even my wife is impressed and she’s never seen the movie. Huge amount of work to be done. So slow and steady. Researching still to find the last of the kit parts. Full scale card mock-up of the buttress to be built next week to resolve some detailing .Wow...those pieces of brass etch. are a thing of beauty![]()
Still a lot of work to do since this is a very repetitive model and complex also.
Thank you. There are few who would take the challenge of recreating the Pyramid and I never expected that I was going to be first to “stick my head above the parapet”. What you referred to in your words has a truth here because the details / nuts and bolts on its construction will be lost if no one researches it and records it. Whatever value we place on these things is , I don’t know if you want to call it cultural or personal, all I know is that it’s important to me.Beautiful work. Incredible hours of research, dedication and craftsmanship. Your Pyramid is tribute to the film, its creator, actors, professional model maker and credit to those that have the wisdom to appreciate it. “All those moments will be lost in time, tears in rain.”
I need to catch up on the rest of the thread... but.. this would be perfect for modelers converting their K'tinga class models into Kronos one.Hi everyone. So the etching company in the UK informed me a few days ago that production is halted because of the COVID-19 crisis, it will be some time before this aspect of the build can be sorted. I’ve also been told that the company laser cutting the acrylic sheet for me has also closed. Anyhow, this is to be expected. Attached are images of the some drawings I did for the etch. The larger is my version of the original master. It measures 12x24 inches. The tolerance for the minimum line thickness is 0.5mm In order to be etched cleanly. Which meant I had to modify and adapt some areas of the original detail. This might explain why you see original etched parts looking a bit rough, where lines very obviously blow out. The two drawing on the right are the ones going to etch. One at full scale and the other at half scale.
Joberg,Great trick and great results; I wouldn`t change a thing![]()
True, tech is great when it serves youJoberg,
Would you believe that I have already altered and revised it. Ha, Ha. I re- watched a segment of the making of documentary again this afternoon. There’s a tracking shot close to the buttress. i though the lights/windows looked a little smaller and more rectangular, so I altered them and will print again over the weekend. I can do this easily in auto cad since the windows are drawn as a block with specific measurements. You can alter parameters of the block‘s measurements easily and then the drawing will update all the windows to the new shape. isn’t technology great when it’s works,
