Unlimited Run Aluminum vibro axe blade
This is what I based it on
Here is the correct cut on the vibro axe dl44 greeblie. The size and angle of the straight blade screws is correct also. The back is filled with some kind of putty. Hope this helps the axe builders out there.
Thank you so much!
This is amazing!!! I’m starting to collect the parts for mine and was wondering do anyone make the Yamaha blade part and the the cross standoff for the hairdryer and the stand off for where the small tube attaches to the main pole? Also looking for anyone that either sells the Vader rod or anyone that could provide measurements for an accurate Vader rod they could send me?
Hello there, thank you for your kind words. The greeblies I do have are:
Yamaha xs1100lg greeblie
Big Phillips hairdryer screw greeblie
Pole to rod connector greeblie
Cannon an3106b connector full resin cast
Cannon an3106b connector lock nut only cast
The top faucet snap nipple greeblie has become non existent since I finished this axe. I have a spare but I'm keeping it to make a cast. The stunt axe is resin. The axe used in Jabba's palace has all the real parts on it.
Hey Ryan, I just sent you a private message with some questions regarding about the stuff you have available. Thanks so much for responding.
I just noticed this today, the disc underneath the yamaha xs1100lg greeblie is also on a Y-wing helmet. The notch or imperfection is the identifying mark that confirms it.
This is crazy, I have some discarded disc greeblies I had machined and I put them in a discard pile because they had some really sloppy machine marks left on them. One of my crummy discs actually had pretty much the exact same mark in the same spot left on it.
