I’m in for a blade and a stencil kit!
Dave, i'd love a stencil kit please . USA
I'm in for stencils only. please
Thanks everyone. Much appreciated! I've updated the list with everyone's preferences.I am in for full build if that includes fully painted/finished hilt.
Would you also happen to have the 2 screws for the Yuma Box?Dave, i'd love a stencil kit please . USA
That's great, Kraig. Thank you. I've updated the list. CheersI'm in for a blade and stencil
Absolutely. That's not a problem. They're 30mm M4 if you need them sooner. For my parts at least. Cheers.Would you also happen to have the 2 screws for the Yuma Box?
Thank you! Much appreciated. I've updated the listHello.
I'm in for the complete build.
I'm international based.
Thanking you in advance.
That's awesome! Did you ever visit the set location? Would be a cool road trip. Bit far for me in the UKHA!!
i was Born in YUMA!
Thanks I don't chemically darken myself. The metal looked pretty clean/new on the Yuma shoot. Although I have seen some great results where people have used aluminium black. Personally, I just dull the surface with scotchbrite pads and steel wool, but that's all. Then I knock the paint back with the pads once it's cured. I've considered trying the Birchwood Casey on just the emitter (then knocking back before stenciling). I could try it as an option for people to see what they think before the run goes ahead maybe?Looks very great.
What process steps do you follow for your completed version? Do you darken the aluminium first or apply directly the stencils on the machined finished body?
Thanks for your answer and great work
Many thanks for your answer.Thanks I don't chemically darken myself. The metal looked pretty clean/new on the Yuma shoot. Although I have seen some great results where people have used aluminium black. Personally, I just dull the surface with scotchbrite pads and steel wool, but that's all. Then I knock the paint back with the pads once it's cured. I've considered trying the Birchwood Casey on just the emitter (then knocking back before stenciling). I could try it as an option for people to see what they think before the run goes ahead maybe?
Absolutely. Thank you. I've updated the list.Can I get on the list for two stencils please.
Thanks DaveAbsolutely. That's not a problem. They're 30mm M4 if you need them sooner. For my parts at least. Cheers.
Sounds great! The first handful of stencils have actually arrived and look great. I haven't had a chance to take a proper look though just yet as I've been putting all of my time in to finishing my remaining 2020 commissions. I'd like to get the full sheet applied on to one of my hilts to check everything fits property before sending any out or ordering more. They do appear to be spot on though! Looking forward to giving them a test run once I've freed up a bit more time. As soon as I've tested them out and know they're good to go, I'll get some more ordered. It'll probably be in the new year now. Hope that's ok.I have an awesome plan with these stencils Dave...when they come in i have a technique i'm going to try for a custom Yuma that, to my knowledge, hasn't been tried yet for this hilt. I will make sure you are the first to see it since you are a Yuma fan so...you might want to put me down for 2 sets of stencils instead of 1 in case i screw up...lol. Thanks again
