The Ultimate Ben Obi-Wan Kenobi Real Vintage Parts Lightsaber Group
Well I finally got my transistor set from ParfaiteLumiere (thank you again for that!) and I managed to find a clamp that, while a bit more weathered, was not in horrible condition. And next Monday, thanks to Edraven99, I have a nice male balance pipe coming to me, and I'm already talking to Roman about getting it converted. All the pieces are falling together....
Now here's an issue. The way I did my bubble strip I actually sanded it down to be flat (no other reason than that's how I like it.) However, I found the fatal flaw in doing that, where the bubble strip now falls out of the clamp :s any ideas on how to fix that?I was thinking clear double sided tape, but I am open to other suggestions barring buying another calculator.
I have tiny elastic bands on either side of the bubble holding mine into the Luke Graflex clamp...
Damn looking through this thread I miss my collection. It's still all boxed up from my move.
Waiting on an exatra as well to finish mine off... and I found a couple of lower profile transistors I THINK I got from teecrooz way back... I'll have to take a shot and post to find out.
This works well. I used a small hairband (the fabric covered type) cut in two to the length of the clamp rails and tucked them inside the rails; then slid the bubbles in. The bands keep the bubbles centered and keeps them from falling out.
Waiting on an exatra as well to finish mine off... and I found a couple of lower profile transistors I THINK I got from @teecrooz way back... I'll have to take a shot and post to find out.
Looking very fine there userd1402. I'm still waiting for my Hales to arrive from the UK via sea mail.
Hey fezfox ! When did you pick up a Hales? I hadn't realized you'd started down the long path.
Congratulations!
My condolences. ;)
And Good Luck!
May the Force be with those of us on The Long Path!!!
Trying to do a trial fit right now. Anyone else have issues threading your booster onto Romans Empire spacer? I can get about 2 or 3 revolutions on before it gets stuck. Meanwhile, it came with the flash suppressor and the screws all the way on without issue.
Hi, will try to answer your question, someone will correct me if I'm mistaken. The booster doesn't thread into the spacer, the treaded part goes into the handwheel.
have fun with your build :)
There are threads (female) inside the gear/radiator portion of the booster and there is a male threaded end on the spacer to fit it. There is an extended male end of the booster with threads that DOES go into handwheel.
yeah sorry, I was searching on Roman's website because it felt weird that you asked that and realized what you meant, sorry about that. I hope someone can help you :$
Are you talking about Roman's hollow F/X spacer? Its made of steel I believe. I'm not 100%, but I think there are lubricants you can use for threads so that they don't bind up. Not sure if you can just use WD-40.
Trying to do a trial fit right now. Anyone else have issues threading your booster onto @Romans Empire spacer? I can get about 2 or 3 revolutions on before it gets stuck. Meanwhile, it came with the flash suppressor and the screws all the way on without issue.
While I imagine all boosters are threaded the same, I'm guessing the cutters wear down after a few hundred boosters... so the first hundred may have nice smooth deep threads, while the next hundred or so will be tighter due to a dull cutter.
Wanna send me your booster? I'm about to run more hollow spacers and can make sure one fits your booster.
