Does anyone have any ideas on the under barrel boxes? I have everything planned out and Im about ready to start building but I cant figure out how to get those grooves in the under barrel box. Thoughts?
And while we're discussing the baby cannon, the oversized barrel tube, and box under it, how do you plan to attach those to the gun itself?
There are no obvious pins or screws.
So, I was chatting with a fellow on another message board about that dremel table and he says it's junk. I have not used it. I just thought I'd let you know. I don't use dremel products because I like black and decker more, so I use a black and decker rotary tool. It takes all the dremel tips though.
Anyway, I'm not sure what I'm going to do for my baby cannon build yet in terms of materials. I'm leaning toward a steel tube for the barrel, and an aluminum box with some MDF inside it so it's not just hollow. I was thinking of attaching them as I mentioned before, via the top strap of the gun. I would tend to screw/pin/or bolt everything together though so it can stand up to being fired. Blanks though, I'm not sure I'd ever trust an RG revolver with live rounds.
I couldn't build something like this and not fire it. BUT, I don't have an RG revolver yet, so, it's academic.
The crosman build will be easier. I'm just planning to use MDF for the box, maybe with aluminum panels. Though I am tempted to rig this sucker up with pyro like they did for the film. Very tempted.
GREYLOCKE! You found it. Very cool man. Thanks to a thread about a stunt vektor, I found THIS:
RÖHM Sportwaffen - Focus on Quality - A member of the PW Group
This is currently in production, I have no idea how to get one in the states though. But it's damn close, ain't it?
What you CAN get in the states though, is this:
R1 2.5" Revolver Set - Gun (Black), Ammo, Holster
I'm betting a swapping out of the grips with something close would help, but that's pretty much the same model as they have on the RG site as the model 69, and the models look really close, just need to change the grips.
Also, just thinking out loud, I wonder if any other parts from the Brass Eagle Cobra pump may have found their way onto that baby cannon.
