</SPAN><TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD CLASS=$row_color>
E.D.C. Studios wrote:<HR></TD></TR><TR><TD CLASS=$row_color>
you know, I originally thought that the D-ring bracker was mounted slighty off center, but after a practical test, i.e. actually putting one on a flash, it would seem it may actually be on center.
</TD></TR><TR><TD><HR></TD></TR></TABLE><SPAN CLASS=$row_color>
I did the same thing. If you line up one of the hardware clip and dees with the rounded edge at the inner lip of the bottom of the flash, the strap portion is fairly well on center. When you do comparison angle viewing, everything seems to match up with the photos even with the strap being one center.
As for the Kenobi saber, I believe that there's a higher resolution picture out there. I'd done a graphic overlay showing how parts of the engraving on the band all of a sudden disapeared right where there was some sort of line of demarcation, and where there was "damage" consistent with peeling mylar tape. It's as if there was mylar tape over the entire band, then it came off on the rear portion. Bad plating won't make engraving disapear, but covering it with mylar tape will. I'll try to find my photos.
While I believe that the photo above (when seen in better resolution) shows mylar tape, there's no evidence that this was on the screen used saber. It could have had all the tape removed by then, looked like the one in the photo, or have been completely covered.
I also went back through this thread and concede and appologize for my insistence that you could definitely see 7 grips on the Luke ANH in one of the photos. The dark areas I'd assumed where grips could easily be part of Luke's boot. I'm still convinced there were 7 though.
