hi
could you post up the wiring and which resisters required.
is it same as jedifyfe's diagram?
awesome job mate.. its hard to tell but on the finished picture it looks like you haven't done the blue speckled effect!
Also did you re work the toe with the help of jedifyfe tutorial ??
But smashing built mate.. Awesome collection to any back to the future display!!
Hi!
I love you're work with the shoes! Couple of questions though. I just ordered my first markpoons and can't wait for them to arrive. I see that you completely detached the upper part from the sole. Did you use the same glue that you used with the toe correction to reattach it? If so, how is it holding up? Would it stand normal daily wear? I was thinking of using some sort of epoxy glue, maybe that would work too?
And about detaching the upper part. Do you think it would help to use a heat gun to melt the glue or will it damage the sole?
I actually used superglue and it's amazing, not one sign of it coming loose and when I say I wear them out and about, I have literally been out on numerous nights out in them.
That's not to say there isn't a better more flexible glue that will come apart better for maintenance to the shoes, but for me this works fine.
P.s. thanks for the compliments, it's what makes these hard projects worth while.
hi Luke
what glue did you use?
i went to tesco and saw a few different ones, like Bostik and some other gel glue types.
or did you use a spray one?
thanks
Great job! Where did you get your cuttable EL sheet from?
Loctite superglue. Just the usual tube stuff but with the accurate thin tip. :thumbsup
thanks
i found the link here for the range
Super Glues from Loctite Products | Loctite Adhesives
not sure which to get? liquid or gel?
the gel's one say not good for glueing to foam or rubber?
Luke you absolute legend! Loving the more screen accurate look with the darker grey. Tempted myself now to buy another pair of markpoons mags and do what you've done.
