Does anyone know the reference for the o-rings? Got carried away and tried to put the first 2 on without using the string / floss trick and they landed in the grooves, and can't seem to get them out now. Might have to cut them open and replace them. Feeling pretty stupid [emoji846]
So they just used the screws that came with the wheel? The clip comes with Phillips head screws, right?I bought a bag of accurate Covertec wheels on eBay, some months back, in anticipation of various prequel builds.
My research indicates that the TPM sabers used 8/32” Phillips head screws to mount the wheels, whereas later prequel sabers used the socket head screws, which are less glaringly obvious.
I haven’t seen reference to confirm whether or not Maul’s saber used a Phillips head, but I’m sure the experts can chime in. Looks like the licensed replicas went that route.
Same here, must have spent less than 4 dollars total and assembled everything by hand with no tooling required whatsoever (other than a piece of string if we consider that tooling...)I spent 2 dollars on a rod and like 28 cents on a washer for the middle. There was no extra tooling needed. He was very upfront about the rod not being included.
Yeah, only so much I can do with the box needing to be so long and the cost of international shipping. Having it included with the original kit would have made the original shipping much more expensive, but I do see how that could have been better for the international people. I still say get local if you can instead of from me since it'll be waaaay cheaper.
I think it's more a "we got lucky cutting the ends and didn't have to dress the threads at all" situation than finding a rod that size in the wild.
Sorry should have mentioned I got my local hardware store to cut it to the right length for me (20" 1/4) off of a 24" piece but I would think that any Home Depot, Lowe's or local store would be able to do it as they most likely have the tools readily available.For those who have sAid you didn’t use any tools.
Have you found threaded rod 20-1/2” long?
Or did you forget to mention the only tool you used was a half saw?
If you have found a threaded rod the correct length could you please share it so I can link it in my tutorial thread?
Thanks!
Fantastic video once again! Thanks so much. You're a life saverTutorial is up! I’m going to start a thread but the first 2 posts won’t be done until I get my wheel
Please feel free to share your techniques and photos there!!
