Various OT lightsaber WannaWanga parts (new ALU MPP shroud)
Thank you so much, Roy. It is all installed.
Maybe you didn't believe it would ever happen. Maybe you gave up on the Empire.
Maybe you redeemed yourself and gave yourself over to the bloody rebellion!
But just in time to make peachy 2020 turn to the dark side, after more than a year in the making, WannaWanga presents the all new
MPP STEEL SHROUD!
Now available WITH free paint stencil for accurate weathering result.
$55 (ex. shipping and for EU members ex. VAT)
(D-ring & thumb screw not included)
https://wannawanga.com/product/steel-mpp-shroud/
And still valid today:
Cheers!
Roy
MPP STEEL SHROUD!
Cheers!
Roy
Just ordered 2! Now I need Romans Empire to get some MPPs back in stock!
MPP STEEL SHROUD!
Cheers!
Roy
I must have just missed it, I'm getting a coupon expired message for BLACK2020. That's what I get for not checking the RPF earlier today!
Just got this beauty in today. Tried it on my Roman's MPP, but unfortunately it doesn't really fit. What replica MPPs will this steel shroud fit? Not in the loop on other replica options aside from Roman's.
Ive seen some others with a similar issue with a ParksV1 and Romans - sitting around 1mm too high. (there should be a gap between the plastic housing and shroud - but not this big).
Do you have a photo side on, how far off the Side Screws does the Shroud sit?
I do not have mine in-hand as yet, do you know if this issue of not fitting correctly also effects vintage MPP I was of the understanding the V2 Shroud would accuratly fit, I hope this is not a repeat of some V1 Shrouds not accurately fitting vintage MPP.
Added side screw image. You will also see inside the locking screw hole, how far off the screw indent is. It looks like the inner lip of the shroud sits low and needs to be lathed higher.
View attachment 1377668View attachment 1377669
Thanks for the photos, yes that is clearly off, I am sure Roy can make good.
Roy roygilsing are you aware of this issue, is this a one off machine shop error or a common issue of the V2 Shroud?
