Limited Run RUN CLOSED * DL-44 ESB Blaster Machined Parts Set * RUN CLOSED
just placed my order! thanks boba for everything!!
edit: i ordered both sets of bolts
Everything was discussed in this thread and my other greeblies thread.
I could try to sort through it all but only posting the picture s does not convey the discussion associated with the pictures, so it's best to read the info so you can make better informed decisions.
Thanks BD! I'll search the thread for the terms.
How in the heck did I miss this thread? I've been thinking I need a Han blaster for my collection. Oh well, maybe next time.
I am so confused right now.....
All these options, but I'm not sure what is what, which one I should order, and what the differences are. There are terms being used here that I have attempted to learn, but as someone who has only a mid rage of understanding of these blasters, most of it just makes me nervous.
I want to put in an order on my scope, but have no idea what to order.
I am trying to replicate the Han Bespin.
Bespin Han = mount with Bespin disk/spacer and M19 Scope with round light socket (no notch).
Pretty sure Bespin Han has the full/round socket, no?
Guys, I can't figure it out because I have no internet and have limited time online at work (it's naughty!). What do I need for a Luke ESB? sorry if this was answered 3 posts previously, I have precious seconds here ;). Hope to get an answer to you soon bobadebt, sorry if I'm behind (just moved countries)
I think that Luke Bespin and Han Hoth have larger front bolts.
Han Hoth
Luke Bespin
Check these pictures .. Thanks Newmagrathea..
I think its :
Luke Bespin: Larger front bolt. Scope Notch.
Han Bespin: Normal Bolts. No Scope Notch.
Hoth (version): Larger front bolt. Scope Notch
Hoth version has Pistons, Bespin version doesn't
But I could be wrong?
I think its :
i went by the same photos and came to the same conclusion
man that took a lot of time to figure out what I had ordered. Just emailed you with deluxe machining for 5scopes.
No pistons.
So I'm trying to do a Luke Bespin and I'm not sure I understand the options. Can you guys help me out? Here are the scope details:
Piston Machining/side counter bores... Does anyone have a picture of what that is? I'm not sure if it's relevant to the Luke Bespin???
Light Socket – Full Ring or Notched Ring... I can't seem to find a discussion on this either. Is this the brass circular ring on the side of Luke's blaster scope? What are the variations for?
*just read that it should be notched... But still would appreciate any explaination of what this is referencing ;)
Scope Bolts - Standard or Thick Head... This one I think I'm good on. Luke's Bespin scope mount appears to have thicker screws so non-standard thicker ones should look good.
It sounds like Luke's Bespin DL-44 is the least commented on, so I'm a little unsure of the commonly accepted thoughts on this.
Thank you!
Thank you!
Luke's Bespin blaster has one standard bolt in the back, and one thick bolt in the front. It looks like Han's Hoth blaster has the same, although the front bolt looks a bit crooked, and there are shadows at play, so it could be a standard bolt.
Yes, the light socket is the round part on the side. Luke's Bespin blaster has the notched socket.
No pistons on Luke's blaster.
The piston machining is an attempt to replicate that area on Han's Hoth blaster. Though there are theories, nobody really knows exactly what's going on there, the photo is just too dagummed blurry.
Yeah, that's the consensus. I'm not 100% about the distributor greeblie, but that's what I've got on my replica
