Mouse Vader
Looks like we both got a little side tracked & it's well past my bedtime.
There’s black and white footage of them dueling with out any rotoscoping “only a master of evil darth” is the famous part I quote where you can clearly see the entire emitter spinning
&Like Tom said. We know 100% the emitter was built to spin with by the motor, Brandon explains he took it apart and examined how it worked and there is even signs of how the motor was mounted inside
We are absolutely sure of the V2's construction from the outside, and from a basic standpoint inside. This is from those videos of it once Brandon got ahold of it, and from Brandon himself. The whole emitter is separate, with set screws underneath the emitter lip, in the nipple and they are affixed to the steel rod running down the neck, that has something attached to it to keep the emitter on inside the upper grip.
That‘s what I think, too - that the V2 emitter is a separate piece produced on a lathe and was then married to the cast aluminum „body“ of the V2. Jon told me that a group of people was working on the special effects sabers for ANH, so it could be possible that they used different ways to create the mechanical effect. What if - just a theory - during ANH production, only the plug/nipple/insert in the V2 emitter rotated together with the blade? Could they probably have used some sort of a shaft and tube system? That was my first idea when I thought about how they created the spinning blade on the Obi saber.That's a good question. I'm not sure - but I do know the emitters of the V3 and V2 are different. The top plate is much wider on the v3, I've had an idea for a while that they produced a separate emitter for the V2 or lathed up the one they cut off the cast
In the second screen grab, he is letting the grip go with his right hand... no wire seen.
In the screen grab, an interesting thing I note in the video is that when they yell cut... AG focuses on the lightsaber and seems to look to a switch? to turn it off?
two Qs and observations.
in the first pic someone said there is a white wire running up his sleeve.
Why make the wire "white" and very visible
could the white in the first image be his white sleeve?
