Finally I'm FREEEEEEEEE!!!
I already shipped all the orders and did not take any orders this month of July so I can continue working on my helmet build that's been idle for so long...
I made a new cast for myself... applied a coat of primer filler... it is still in 4 separate pieces...
But before I touch the helmet again, I will proceed first to my "EUREKA" moment...
:thumbsup
I INTRODUCE TO YOU MY "SEE-THRU LED EYES"...
This time with a much better long lasting coin battery (CR2032)...
Thinner LED eyes enclosure... about 3mm
Power supply with ON/OFF switch and provision for additional switch (reed switch, etc)... temporarily put a jumper wire (red short wire)
Have a clear lens, engraved lens, and amber tint (for glare reduction inside the helm)
Clear lens installed...
Light is only intensify around the edges of the clear lens...
Not really that bright...:confused
I engraved some diagonal lines (using a scriber) on one of the clear lens in hopes that the lines will illuminate when light passes thru it... you can use a laser engraver for a much precise lines...
Installed the engraved lens...
Turned the lights ON... and
VOILA!... the lines illuminates and the whole lens lights up...
Engraved lens is a SUCCESS!!!
:thumbsup
The amber tint were then installed at the back side (face-side of the wearer)
The amber tint reduces the glare thus lessens the eye strain of the wearer... not much noticeable in the photo but believe me it is very effective in actual...
The power supply has a double-sided foam tape for easy installation...
Simple installation...:thumbsup
This is how the clear lens looks like when lit installed on the face plate...
This is how the engraved lens looks like when lit installed on the face plate...
Engraved lens (left) vs Clear lens (right) - Direct comparison... (room lights ON)
You can notice the big difference in luminance... (room lights OFF)... Clearly the engraved lens is brighter...
Camera shot with flash...
The clear lens wins with regards to visibility...
But its not that bad with the engraved lens... You can still see much of the surroundings though like seeing thru screened doors...
And this new SEE-THRU LED eyes design allows the wearer to see thru the lens and under the lens (the open slit of the eye socket)...
Therefore, I will stick on the engraved lens. Although not that movie accurate but I'm sure this will give me more advantage while wearing the helm in a convention...
:thumbsup
Similar to my 1st design LED Eyes, this new SEE-THRU LED eyes have the following qualities:
1) Compact design (no messy wire running along the helmet)
2) Very light weight
3) Energy efficient (uses lithium coin batteries, 3V)
4) Provides just the right light intensity (not blinding)
5) Shape is movie accurate
6) Allows the wearer to see thru it and thru the open space (slit) of the eye socket
7) Minimal glare (less strain on wearer's eyes)
8) Ideal for motorized face plate
9) Easy to install
10) ON/OFF switch provided
And you can make your own or I can make it for you (LOL
Thanks for watching and for your time... more updates on my helmet build coming soon...
cheers!
