A quick question, does it bulge up at the palm area when u pull back your palm? as I am lost between making the gauntlet out of paper+resin or foam.
Are you planning on incorporating the repulsor sound? If so, do you have an idea for keeping it in the glove or will you expand into the gauntlet?
BTW, Nice job on the switch to turn the repulsor on. I would be interested in more details regarding that.
Yes we are planning to incorporate the repulsor sound... initial idea is to put the small speaker and sound circuit on the part that covers/guard the top of the hand... repulsor switch will be the same switch to trigger the sound...
Thanks for appreciating our work... we're planning to make a run of this as well...:thumbsup... try to look around, its there somewhere in the J...
cheers!
Is there a picture of the switch you guys used?
Yes it kinda bulge up (a little)... but the gauntlet should be made with the surrounding patterns (on the repulsor) a bit thick thus compensating the repulsor bulge and will give you a seemingly uniform flatness...
Hope I'm able to explained it clearly...
cheers!
cool. Now I got it. Thanks
What material did you use for between the foam? The ribbed material.
Nice one, thanks! Your work is some of the best I've seen.I called it flexible conduit:confused... but later I was told it was split wire loom...:thumbsup
Man that looks real nice. I like the split wire loom. Never thought of that.
hi there,great job! how much you ask for the gloves ? Thnx Ford
Awesome and inspiring build. I "Might have to" (read must) try that myself sometime soon.
I am looking forward to updates.
Hey Guys...
Almost everyone is into FOAM Ironman build right now... so we cant think of a more logical thing to do but to jump in to the FOAM band wagon... lol:lol
Since most Foam Ironman builder started with all the big pieces, my brother on the other hand (literally) started on the gauntlet...
He used zabana's pep file (thanks man:thumbsup) just removed the tabs...
Here are the WIP photos:
He used 2mm EVA foam
Laid out the patterns...
Made the whole palm assembly
Joining 2 layers of 2mm foam to achieve the right thickness on the palm... He used contact cement or rubber cement to join the 2 layers...
For other parts he used super glue...
Then came the thumb...
The index finger...
He temporarily attached the finger parts using masking tape...
A bit of test fitting...
Then the middle finger...
And finally the complete fingers done
It turned out quite good though he found many things to be improved...
Next (left gauntlet), he'll try to use the FOAM pep patterns provided by stealth...
I'll be sewing the fabric gloves that will go underneath this foam gauntlet...
After that will be the installation of the repulsor...:love
Comments and suggestions are highly appreciated...
Thanks for watching... cheers!
nice...
