Little Fett
Member
So I thought I'd try my hand in the hock business, so I sculpted, and casted in silicone a basic Jason part 3 hockey mask. I'm pretty happy with the glossy texture. Ok, hard part done right? Maybe not:angry.
I tried making my first cast using one piece of fiberglass cloth; applying resin, cloth, resin to the inside of the mold. all pretty simple. the resin kinda pooled in the nose area, but otherwise it looked pretty good.....until I pulled it.
I found bubbles had gotten between the cloth and the mold, leaving large craters in the finished mask. Also, some areas came out totally clear and flimsy, despite having cloth and resin just the same as the other areas :confused.
I then tried using cut pieces of cloth (same resin, cloth, resin application), which improved the problem, but didn't solve it. I still had bubbles and the same weird clear areas.
I'm using Elmers fiberglass resin and woven fiberglass cloth. What am I doing wrong??
