PHArchivist
Re: Converting the FX toy X-Wing into a display piece
Had an epiphany oday about how to ensure the cannon barrels are straight in line with the cannon bodies.
I gutted the two body halves, then inserted a glob of Sculpy to use to properly oistion the cannons. The Sculpey is - of course - maleable, but has no spring tension, so once in place, it stays there. And it is sticky enough to hold the cannon barrel... Quick tack-down with CA glue, then smothered it al in epoxy, and viola!
By the way, the barrels start at 9/32 for the primary barrel, then I installed a 1/4" insert into the 9/32 tube, and then a 7/32 tube for the secondary barrel. The 8/32 (or 1/4) insert provides the proper step from the primary barrel to the secondary.
