DG Reid
I'm pulling together a No Face for con and I'm bogging down in how to build the face itself. It's going to be somewhere around the size of 12"w x 16"h. It is going to be mounted to the structure of my costume so I don't need to see through it or attach it to my face.
So far I'm seriously considering:
a. Paper mache method using glue as the binder and old cotton sheeting as the material with maybe a layer of sculptamold to smooth it out.
b. Carving it out of rigid foam insulation and sanding till smooth. Probably priming with something, not sure what, to smooth it out further.
Basic tools and skillset, low budget. Needs to be paintable and very smooth, light and rigid but not especially fragile.
Do you think one method would work better than another? Would you suggest something else?
