airair
Thanks Man & Airair
The Cloneprops buckle I posted with the inverter inside is off a 3v, 2xAAA batt inverter, it actually started 13cm long but now it's stripped i think it is suitable for the job however the 3v coin cell when they are available again I will get two for the v2's(not these as I want to stick to 9v rechargeable with 750mah.
Right the switch should be ignored on the inverter and instead run another (+) to the switch on the v2, will it work? I really don't know as I don't have a pair to try this on, but I don't see why not as the switch makes the connection for the lights.
Remember at this stage it's trial and error, we know nothing about the v2's electrics and that will be my job to figure out and write up a thread with my findings
Ps I got my D.C Port jacks from eBay, I would advise buying an adjustable voltage d.c power supply as you will need it to be 3v, also on eBay![]()
if you are just doing the strap light and nothing else for the v2 knockoff.
i think the battery for the v2 which sounds like its in the soles and its probably lithium i think.
if you simply ran wire from that existing v2 knockoff switch to your inverter, and a wire from inverter to the battery somehow, that would work i think?
im trying to think of the method for the scratch build. but definitely plan to do the strap light addition immediately.
it would be great to have the el light in the strap, and the leds in the soles all light up from 1 switch.
we don't know what battery though is being used in these shoes yet, so that may need to be checked in case anything blows up!
you never know with these knockoffs!
