Limited Run Aliens Pulse Rifle Parts (Shrouds, Vents, Stocks, Grips, ect.)
Sorry about the delayed response to the questions.
For fitment on a Snow Wolf/Matrix: AndyHoff I can't speak to it as I have not seen one in person or anything but I think CoCost has accurately described it. I think the Snow Wolf is based more on the versions of the PR that had a straight pipe replacing the entire Thompson barrel where this extension is made to look like the extensions/choke that was added to the live fire hero PRs.
maxhebus this barrel extension was made to be pretty generic so it would be more likely to fit a variety of barrels. It has an 11mm inside diameter which is the same as the end of the WE Tech barrel and I believe other airsoft variants so the easiest option is to use a piece of 11mm tube as a bridge, so to speak. I personally will be using a piece of K&S 11mm brass tube.
View attachment 1799247View attachment 1799248View attachment 1799249View attachment 1799250
Thank you for your answer. Funny how I always imagined it with a died end like the real one. I've seen and read to much about the Hero one. :D
True that for airsoft's, there is no need. 11mm brass tube it is. I can't wait to have my hands on them.
Just to expand a little on the quickest/simplest way to attach the barrel extension. Here's a pic of some of the 11mm brass tube which fits in as a friction fit. A person could even solder or glue it in if you really wanted to, but that would likely be overkill in most cases.
Anybody else need to jump on the extended opportunity for amazing M41A parts offered by dr_slurpee from page 1list?
I can't put it on alienslegacy forum. Not sure why, my account doesn't work anymore...
Could someone else do it?
One last quick note, we have sold out of a number of items but had a few people express interest. We can make more but would need at least 10 people ready to buy for any given part in order to make it viable. I have created a new list of grips in particular in the first post so if people are interested in something make sure to let us know.
Hi,
Interested in:
Grip
10 hole grenade block
10 hole Barrel vent
10 hole Shoulder stock
Shroud set
Extra Mag base
Magwell tabs
Barrel extension
Hi,
Amazing job!
I’d be interested in following parts, provided the Shroud is once again available
Grip
10 hole granade block
10 hole Barrel vent
Shroud set
Extra Mag base
Magwell tabs
Barrel extension
Hey Slurpee!
Mind adding me to the following available and interest lists as well?
Grip
10 hole Barrel vent
Shroud set
Extra Mag base
Magwell tabs
Barrel extension
Thanks!
I apologize to everyone who may be waiting for me to reply or something. I’ve had a family emergency so I’ve not been around. I’ll do my best to get things updated as soon as possible
Does anyone know where to get the:
-green magazine end cap with the hole to enable quick mag wind
-metal sling attachment pieces front and rear
-realistic sling
For the Snow Wolf / Matrix M41A
Hi Slurpee
Could you add me to the list for the following: -
Shroud set
Magwell tabs
Barrel extension
(I tried sending a message through Alienslegacy, so please ignore as don’t want to duplicate)
Thanks,
Tim.
I have been working with a friend to create a number of high quality Pulse Rifle parts. They are a combination of known research and our own in order to dial in the parts. These will be limited run and no payments taken until the parts are in hand and ready to be packed and shipped.
Contact me to check on shipping, buy, or be added to the interest list.
Thompson Grip
View attachment 1759672View attachment 1759673
GBP£37.50 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
  • Made to fit the WE-Tech Cybergun GBB M1A1 Thompson. (may fit others but unknown)
  • Original model master incorporating a blend of the features of all the PR grips.
  • Cast in high quality, impact resistant, black urethane resin.
  • Base screw plug cast off a real Thompson grip screw.
  1. Interest List - vectorzero
  2. Interest List - maxhebus
  3. Interest List - maxhebus
  4. Interest List - Carrett
  5. Interest List - ObscureReferenc
  6. Interest List - AndyHoff
  7. Interest List - AndyHoff
  8. Interest List - Cross57
  9. Interest List - Ram77
  10. Interest List - Available
Grenade Launcher Blocks
View attachment 1760463View attachment 1760464View attachment 1760465View attachment 1760466View attachment 1760467
GBP£49.00 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
  • Created based on photos/research from the original parts, information from "BugStomper"/Pulserifle.net, and known measurements.
  • Solid machined aluminum, cut from aircraft alloy billet, bead blasted finish.
  • 8 Hole version is 72mm tall, 38mm wide, 25.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
  • 10 Hole version is 72mm tall, 38mm wide, 13.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
  • Holes for grub screw 2.5mm dia, ready to tap for M3 (or you can drill larger for a different size)
8 Hole Block:
  1. Interest List - Bacta
  2. Interest List - Available
  3. Interest List - Available
  4. Interest List - Available
  5. Interest List - Available
  6. Interest List - Available
  7. Interest List - Available
  8. Interest List - Available
  9. Interest List - Available
10 Hole Block:
  1. For Sale Now - Carrett
  2. Interest List - Cross57
  3. Interest List - Ram77
  11. Interest List - Available
Barrel Vent
View attachment 1759932View attachment 1759933
GBP£94.00 each plus actual postage from UK. Tracked shipping to the US GBP£20.00 (combined shipping would be quoted separately)
  • Created based on information from "BugStomper"/Pulserifle.net
  • Made from accurate 40mm square mild steel tube with 3mm wall
    • Matching material and specs based on first hand research at Bapty
  • Inner Diameter of the barrel ring is 19mm
  • Milled and welded professionally
8 Hole Vent:
  1. Bacta - PAID and SHIPPED
10 Hole Vent:
  1. Interest List - maxhebus
  2. Interest List - Carrett
  3. Interest List - vectorzero
  4. Interest List - Ram77
Shoulder Stocks
View attachment 1759930View attachment 1759931
GBP£94.00 each plus actual postage from UK. Tracked shipping to the US GBP£23.00 (combined shipping would be quoted separately)
8 Hole Stock:
  2. For Sale Now - Available
  12. Interest List - Available
10 Hole Stock:
  1. Interest List - Carrett
  2. Interest List - Ram77
Shrouds
GBP£375.00 per set plus actual postage from UK. Tracked shipping to the US GBP£29.00 (because of some logistics we cannot combine shipping these with other parts)
These will be sold/shipped as they are completed/ready based on the order of the interest list, no money taken before hand.
  • Based on photos of aluminum hero shrouds and first hand research at Bapty (cleaned up to be made straight and symmetrical)
  • High quality professionally made aluminum-filled, fiberglass shrouds, and mag butt caps.
  • Uniform thickness around 3mm, STRONG, light weight.
  • Comes untrimmed, with trim lines molded in for tight fit to a Thompson and SPAS cage allowing for individual adjustment for fit.
  • Open access at the top, between the upper 'handles' (track along the top) for you to fit as strong and light a U-channel as fits your build. This allowed us to keep the thickness uniform, reduce cost and weight.
  2. Interest List - Joatrash
  3. Interest List - Cross57
Extra Mag Bases
Additional Mag Bases available for anyone wanting to have extra mags on hand for their Pulse Rifles. These are the same as what is included with the Shroud Sets.
GBP£36.00 each plus actual postage from UK. Tracked shipping to the US GBP£10.00
  1. maxhebus - PAID and SHIPPED
  2. treeboar - PAID and SHIPPED
  3. vectorzero - PAID and SHIPPED
  4. For Sale Now - Carrett
  5. For Sale Now - Cross57
  6. For Sale Now - Ram77
  7. For Sale Now - Available
  8. For Sale Now - Available
  9. For Sale Now - Available
  10. For Sale Now - Available
Magwell Tabs
Milled from aluminum like the originals on the hero with bead blasted finish.
View attachment 1780284View attachment 1780285View attachment 1780286
GBP£22.00 per pair plus actual postage from UK. Tracked shipping to the US GBP£10.00
  • Designed to match from photos and reference first hand research at Bapty
  • Come with correct rivets (we recommend cutting the rivets off and gluing the tabs and rivets to the shrouds as regular rivet installation can put a lot of stress on the fiberglass and gel coats)
  1. For Sale Now - Carrett - PAID and SHIPPED
  2. For Sale Now - Bacta
  3. For Sale Now - Cross57
  4. For Sale Now - Ram77
  5. For Sale Now - Xhiwar
  6. For Sale Now - Available
Barrel Extension
Being produced now!
View attachment 1798954View attachment 1798955View attachment 1798956
GBP£24.00 each plus actual postage from UK. Tracked shipping to the US GBP£10.00
  • Made from steel
  1. Jim - PAID and SHIPPED
  2. MooseF - PAID and SHIPPED
  3. DarthWilder - PAID and SHIPPED
  4. DarthWilder - PAID and SHIPPED
  5. Moosh89 - PAID and SHIPPED
  6. barney five - PAID and SHIPPED
  7. barney five - PAID and SHIPPED
  8. CoCost - PAID and SHIPPED
  9. Harry Harris - PAID and SHIPPED
  10. userd1402 - PAID and SHIPPED
  11. maxhebus - PAID and SHIPPED
  12. maxhebus - PAID and SHIPPED
  13. maxhebus - PAID and SHIPPED
  14. ObscureReferenc - PAID and SHIPPED
  15. treeboar - PAID and SHIPPED
  16. FullMetalJoe - PAID and SHIPPED
  17. FullMetalJoe - PAID and SHIPPED
  18. vectorzero - PAID and SHIPPED
  19. turok96 - PAID and SHIPPED
  20. Bacta - PAID and SHIPPED
  21. Waitlist - Carrett
  22. Waitlist - septic
  23. Waitlist - AndyHoff
  24. Waitlist - AndyHoff
  25. Waitlist - FokkerVF
  26. Waitlist - Cross57
  27. Waitlist - Ram77
Slings
Photo of the components being used to make the slings.
GBP£37.50 per sling plus actual postage from UK. Tracked shipping to the US GBP£10.00 (combined shipping would be quoted separately)
  • Made from screen accurate 8-band webbing
  • Made from genuine period hardware.
  1. Jim
  2. DarthWilder
  3. mugatu
  4. nick-a-tron
  5. maxhebus
  6. maxhebus
  7. maxhebus
  8. Carrett
  9. ObscureReferenc
  10. MooseF
What is the cost for all parts, how true to hero or actual pulse rifle, do you have spec on material used to match, can these be used on live fire thompsons and if so 9mm or 45 acp?
