Limited Run Aliens Pulse Rifle Parts (Shrouds, Vents, Stocks, Grips, ect.)
dr_slurpee
I have been working with a friend to create a number of high quality Pulse Rifle parts. They are a combination of known research and our own in order to dial in the parts. These will be limited run and no payments taken until the parts are in hand and ready to be packed and shipped.
Contact me to check on shipping, buy, or be added to the interest list.
Thompson Grip
GBP£37.50 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
  • Made to fit the WE-Tech Cybergun GBB M1A1 Thompson. (may fit others but unknown)
  • Original model master incorporating a blend of the features of all the PR grips.
  • Cast in high quality, impact resistant, black urethane resin.
  • Base screw plug cast off a real Thompson grip screw.
  1. Interest List - vectorzero
  2. Interest List - maxhebus
  3. Interest List - maxhebus
  4. Interest List - Carrett
  5. Interest List - ObscureReferenc
  6. Interest List - AndyHoff
  7. Interest List - AndyHoff
  8. Interest List - Cross57
  9. Interest List - Cross57
  10. Interest List - Ram77
  11. Interest List - Leonidas280
Grenade Launcher Blocks
GBP£49.00 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
  • Created based on photos/research from the original parts, information from "BugStomper"/Pulserifle.net, and known measurements.
  • Solid machined aluminum, cut from aircraft alloy billet, bead blasted finish.
  • 8 Hole version is 72mm tall, 38mm wide, 25.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
  • 10 Hole version is 72mm tall, 38mm wide, 13.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
  • Holes for grub screw 2.5mm dia, ready to tap for M3 (or you can drill larger for a different size)
8 Hole Block:
  1. Interest List - Bacta
  2. Interest List - Available
  3. Interest List - Available
  4. Interest List - Available
  5. Interest List - Available
  6. Interest List - Available
  7. Interest List - Available
  8. Interest List - Available
  9. Interest List - Available
  10. Interest List - Available
10 Hole Block:
  1. Carrett - PAID and SHIPPED
  2. Interest List - Cross57
  3. Interest List - Ram77
  4. Interest List - Leonidas280
  5. Interest List - Lowdmekon
  11. Interest List - Available
Barrel Vent
GBP£94.00 each plus actual postage from UK. Tracked shipping to the US GBP£20.00 (combined shipping would be quoted separately)
  • Created based on information from "BugStomper"/Pulserifle.net
  • Made from accurate 40mm square mild steel tube with 3mm wall
    • Matching material and specs based on first hand research at Bapty
  • Inner Diameter of the barrel ring is 19mm
  • Milled and welded professionally
8 Hole Vent:
  1. Bacta - PAID and SHIPPED
10 Hole Vent:
  1. Interest List - maxhebus
  2. Interest List - Carrett
  3. Interest List - vectorzero
  4. Interest List - Ram77
  5. Interest List - Leonidas280
Shoulder Stocks
GBP£94.00 each plus actual postage from UK. Tracked shipping to the US GBP£23.00 (combined shipping would be quoted separately)
8 Hole Stock:
  2. For Sale Now - Available
  12. Interest List - Available
10 Hole Stock:
  1. Interest List - Carrett
  2. Interest List - Ram77
  3. Interest List - Leonidas280
Shrouds
GBP£375.00 per set plus actual postage from UK. Tracked shipping to the US GBP£29.00 (because of some logistics we cannot combine shipping these with other parts)
These will be sold/shipped as they are completed/ready based on the order of the interest list, no money taken before hand.
  • Based on photos of aluminum hero shrouds and first hand research at Bapty (cleaned up to be made straight and symmetrical)
  • High quality professionally made aluminum-filled, fiberglass shrouds, and mag butt caps.
  • Uniform thickness around 3mm, STRONG, light weight.
  • Comes untrimmed, with trim lines molded in for tight fit to a Thompson and SPAS cage allowing for individual adjustment for fit.
  • Open access at the top, between the upper 'handles' (track along the top) for you to fit as strong and light a U-channel as fits your build. This allowed us to keep the thickness uniform, reduce cost and weight.
  2. Interest List - Joatrash
  3. Interest List - Cross57
  6. Interest List - trt66
Extra Mag Bases
Additional Mag Bases available for anyone wanting to have extra mags on hand for their Pulse Rifles. These are the same as what is included with the Shroud Sets.
GBP£36.00 each plus actual postage from UK. Tracked shipping to the US GBP£10.00
  1. maxhebus - PAID and SHIPPED
  2. treeboar - PAID and SHIPPED
  3. vectorzero - PAID and SHIPPED
  4. For Sale Now - Carrett
  5. For Sale Now - Cross57
  6. For Sale Now - Ram77
  7. For Sale Now - Leonidas280
  8. For Sale Now - Available
  9. For Sale Now - Available
  10. For Sale Now - Available
Magwell Tabs
Milled from aluminum like the originals on the hero with bead blasted finish.
GBP£22.00 per pair plus actual postage from UK. Tracked shipping to the US GBP£10.00
  • Designed to match from photos and reference first hand research at Bapty
  • Come with correct rivets (we recommend cutting the rivets off and gluing the tabs and rivets to the shrouds as regular rivet installation can put a lot of stress on the fiberglass and gel coats)
  2. For Sale Now - Bacta
  3. For Sale Now - Cross57
  4. For Sale Now - Ram77
  5. For Sale Now - Xhiwar
  6. For Sale Now - Leonidas280
  7. For Sale Now - trt66
Barrel Extension
Being produced now!
WhatsApp Image 2024-03-11 at 12.24.14_9f56ad1b.jpgWhatsApp Image 2024-03-11 at 12.24.14_52f6c27c.jpgWhatsApp Image 2024-03-11 at 12.24.14_25415143.jpg
GBP£24.00 each plus actual postage from UK. Tracked shipping to the US GBP£10.00
  • Made from steel
  1. Jim - PAID and SHIPPED
  2. MooseF - PAID and SHIPPED
  3. DarthWilder - PAID and SHIPPED
  4. DarthWilder - PAID and SHIPPED
  5. Moosh89 - PAID and SHIPPED
  6. barney five - PAID and SHIPPED
  7. barney five - PAID and SHIPPED
  8. CoCost - PAID and SHIPPED
  9. Harry Harris - PAID and SHIPPED
  10. userd1402 - PAID and SHIPPED
  11. maxhebus - PAID and SHIPPED
  12. maxhebus - PAID and SHIPPED
  13. maxhebus - PAID and SHIPPED
  14. ObscureReferenc - PAID and SHIPPED
  15. treeboar - PAID and SHIPPED
  16. FullMetalJoe - PAID and SHIPPED
  17. FullMetalJoe - PAID and SHIPPED
  18. vectorzero - PAID and SHIPPED
  19. turok96 - PAID and SHIPPED
  20. Bacta - PAID and SHIPPED
  21. Carrett - PAID and SHIPPED
  22. Waitlist - septic
  23. Waitlist - AndyHoff
  24. Waitlist - AndyHoff
  25. Waitlist - FokkerVF
  26. Waitlist - Cross57
  27. Waitlist - Cross57
  28. Waitlist - Ram77
  29. Waitlist - Leonidas280
  30. Waitlist - trt66
Slings
Photo of the components being used to make the slings.
GBP£37.50 per sling plus actual postage from UK. Tracked shipping to the US GBP£10.00 (combined shipping would be quoted separately)
  • Made from screen accurate 8-band webbing
  • Made from genuine period hardware.
  1. Jim
  2. DarthWilder
  3. mugatu
  4. nick-a-tron
  5. maxhebus
  6. maxhebus
  7. maxhebus
  8. Carrett
  9. ObscureReferenc
  10. MooseF
Interested in a 10-hole launcher block and an 8-hole when the finals are ready. Also interested in a shroud and a sling. Thanks.
Updated the first post, I misspoke when I said incorrect dimensions on the blocks, they were created using older info which we made minor changes to for our final versions.
Those barrel vents look very nice! Much more accurate than the ones I have. Please add me to the lists for both a 10-hole barrel vent and an 8-hole barrel vent. Thanks.
Nice to see these parts finally happen. They look beautiful and knowing who's involved, it's no surprise! Anyone looking for PR parts would be a fool to pass up on this run.
I am interested in a 10holes version shoulder stock please :)
this is the only part I'm not happy with on my PR and it is the first time I see someone doing it from actual square tube stock, awesome!
cheers
Eethan's right and settled the debate for me regarding the inferior stocks that I already have . Please add me to the list for a 10-hole stock and and an 8-hole stock, too.
Just got some test samples of the fiberglass with aluminum powder. The pictures don’t do it justice, they are cold to the touch and will weather beautifully to look like aluminum!
Updated for additional information and pricing for shrouds. Currently just an interest list for them not a sale list.
Production sample, only lightly buffed, more buffing will give an even brighter look.
Some photos test fitting a the sample shroud onto a WE GBB Thompson!
