wtac
Hi all
I just wanted to show you my latest project in upgrading Hasbro/Kenner blasters. Having made up a working stock I decided to try and inprove the blaster using as much of the stock item as possible I even used some of the FANTASTIC T Track that saberfreak on this forum found, if you need some track get it now as he only has a limited supply. I decided at the same time to convert it to being an Air soft rifle. I managed to put the electric air soft workings from a semi auto into the Hasbro but made it fully automatic instead of semi automatic. It has a slowish cycle rate as I upgraded the spring so it is easy to fire single shots, it has a 16 round clip which seemed appropriate as a short Sterling clip contains either 10 or 15 rounds. It is HUGE fun and well worth the work involved
Hope you like the concept
