Picking up right where I left off.... At the point of the first picture I was looking over everything that I had done to that point and considering what changes I needed to make, The fiberglass glove mold was not as good as it could have been, but that was due to working conditions at the time. I was working in the warmest day we had had in a couple weeks, but that isn't saying much, I still had to fire up the heater and wait for the garage to warm up enough to be able to work. I learned early on the fiberglass reson, polyester resin, enamel paint and so on didn't react to well to cold, heat, or humidity. Unfortunately, I learned the hard way. After the garage got warm I had worked inlayers on the fiberglass glove mold, but should have taken more time and worked more slowly, I'm going to keep that in the front of my memory, so that I don't make the same mistakes next time. As a result of the weather and the time constraints at the time the mold was in such a fashion that I wasn't to happy with it and knew that it needed more work before it could be a viable, working mold. I knew I needed to key the mold for the silicone I was going to pour in the recess between the master and the fiberglass glove, but before that could happen I had to smooth the innersurface out. I also needed a vent at the highest point of the mold, to vent the air, or any bubbles that might have gotten in with the mixxing process. So, essentially I used binary epoxy resin to fill in the places where the mesh was not smooth, used a hole saw to cut a vent, coated the mold with several layers of gloss enamel white and keyed both sides of the mold.
After cutting the vent out, I used a piece of old PVC to create a chimney, but I had to clean it up for so I soaked it in 91% alcohol to remove in contamination, impurities, and some of the sctoch tape that had been on it. I then epoxied the chimney into the mold. I went back to the earlier photos for reference and aligned all of the parts and superglued, or expoxied them back into the proper position, to maintain the original alignment of all of the components. I used the balsa wood to lift the part off of the main baseplate, so that I could clay around it and give myself a clean cut line. I used used pencil erasers left over from old pencils I had bought back in college as keys.
More to come......
