1/2 Studio Scale Refit Enterprise
Status
Not open for further replies.
Here are a few of the molding photos. With rare exception did I take this much time showing every step of the molding and casting process, simply because I hate taking the time to light and photograph every step of the process, upload the photos, cut, cropand tweak them, just to show how I did a thing, or to prove that I did the work. Unfortunately, after being unjustly called a recaster by someone that didn't have a clue, I've felt that there are times when it is neccesary, so that there is no mistake and someone else doesn't try to take credit for something that I've put thousands of hours into.
At any rate, here's the blow by blow.... Before I put anyting into silicone I inspect it thoroughly and make sure that it's ready for silicone, then I sit down and plot out every move and take notes in my engineers notebook, so that if I miss something, or think of a better way, or even make a mistake, I can go back see exactly where I screwed up. I learned this method of "Quality Assurance / Quality Control" at the University and used the same method, when possible, in engineering, or when designing a new system.
After inspecting the part, especially something this big and detailed and complex to cast, I like to make sure I've got a good method locked in to avoid loss of time, effort and material.
For the engineering hull sections, due to the under-cut and the fact that it needed to be there, I had to come up with a complex mold.
This was the first time I ever attempted anything like this...
Moving forward, I traced out the profile of the part on a piece of 11X17 cardstock, so that I could use that to set my alignment keys before claying the part. I then centered the cardstock on a piece of 1/4 acrylic and taped it down. Next I layed wax paper down over the cardstock and used the weight of my clay to hold the wax paper in place. You can see what looks like a pile of junk sitting on my counter, but that's what I used to create my keys, cut my clay, create my vents and make my alignment keys. I took an appropriate size of schedule 40 pipe and plotted out the centerline, after cutting off the section I needed and then cut it down the center., that way I had two keys that would match up to each other and align the engineering hull so that parts would mesh and the under-cut would be there on the finished part to act as a land for the spine section, not shown. I then marked the engineering hull with a sharpie and used a pen to mark those points to be used later, to match up both halves and ensure alignment between the halves, so that when both came out of the mold, they would align one to another perfectly and there would be an opening for running lighting etc. I used a piece of dowl rod for the same purpose to align the shuttlebay deck and keep everything in reference to the centerline for both parts. More later.
In the link below you'll see movie three of the Refit Project. This movie is essentially a composite of two movies, the first part deals with the condition of the ship and the associated parts when it returned and the second half of the movie shows the reconstruction. I had to skip some things just to keep the movie to a size that was manageable. If you have the internet capacity, wait for the high-res version. It's worth it, because, I used the original high-res photos where ever possible and you will most likely see more detail on the parts than in any of the photos thus far.
Enjoy.
One Half Studio Scale Refit Reconstruction.wmv - YouTube
While waiting for plaster, silicone and epoxy to cure, after working on the Refit Movie III, I did some work on the decals and paint guide, patterns, etc... I used our available reference material and Jim's vector files, as well as the font that we worked on.
Yes, well.... The name was an unfortunate oversight on my part. I believe that when I gave these references away over at Starship Builder some years ago, I named them all FREE AZTEC DUMMIES.... Had no idea at the time that you were going to take offense then and didn't even think about it lo these many years later. Some of the above references came straight from the CG files for DE Edition of TMP, so I assure you we have never purchased, or used your work for any type of reference. Additionally, after giving these away and discussing the thought of creating templates for the entire 350th PL kit, someone did indeed do exactly that while I was being chased around from forum to forum by my stalker. If you have any further concerns please contact me via PM, or e-mail. Thanks.
UD,
Sparkling work there! I'm a bit squeamish about the title of the third jpg, tho
I'm putting the Refit to bed for the Holiday. Doesn't look like I'm going to make the "Black Friday" Deadline. Still, I will have a new movie, showing nothing put the parts for the kit next week and will start taking orders then.
I went back and watched the TMP DE again today, while cooking. I can't believe when stepping back and looking at it how accurate and faithfull we've come to the actual model you see on the screen, sorry, but that's for real.
Talked to "Jim" today and I'm going to incorporate his timer into the ships electronics. Here's a freebie for you all. This is the exact timing +/_ 1-2 millisecounds to the actual screen used electronics.
New Page 2
There will be three different sets of electronics available for this ship, but there will be NO Disco-Prize options available. We will however have additional circuits for the torpedo effect and the switch circuit for the deflector and finally, the deflector shields effect as seen in TWOK. None of these circuits will cost an arm and a leg and they will all be plug and play.
We'll have every option available from CCFL's to UV CCFL's to SupreBright LEDs to Surface mount Super Bright White Ribbon and finally... Light film.
Happy Holidays and Keep on Trekkin! =/\=
John and I have both worked hard on this ship and we want nothing to missdirect the thread. Look at the parts and the soon to come model for what it is, not for what people may say.
Thank you for building this kit. Now, I dont have to attempt one. Maybe I missed this, but once I know a price I can set aside the money so I can purchase a kit when it is first offered.:lol
Just so everybody knows, infighting about issues that originated outside of the RPF is not wanted here, personal issues should be resolved via pm or email, or maybe a phone call.
The thread was cleaned up to bring it back on course.
Michael
RPF staff
Got to see some of these parts up close and personal over Thankgiving, and they are beatifully made and cast . . . .and very intimidating!! Looking forward to seeing it all wrapped up!
Status
