Not to shift focus away from this awesome build, which I will be buying when kits come available. But dose anyone have any information on this base used to make this ebay listing?
It's clearly a toy repaint, but has anyone seen it before, dose anyone have access to it?
Blade Runner Blaster Snub Nose Toy Replica | eBay
It is very diffent from the other toy blaster
Krylon Grey base primer, Krylon Stainless Steel, and Krylon Oil Rubbed Bronze were all usedf for the paints.
Some of the metal castings cleaned up a bit and test fit with the resin parts. The metal parts are actually slightly larger than the resin ones. This is due to the molds expanding from the hot metal, which then cools and sets while the molds are still hot. All in all, the mix of parts still fits together pretty well. The barrel is actually one I machined from some steel rod, not a metal casting
do you still offer a resin kit?
Wow! So.....will you be doing a limmited run of metal kits, or metal upgrades?
I'd be interested in either should they become available.
I will not doing either metal kits or parts, but will be doing a few custom metal built up blasters for sale as completed units.
