sebmodio
Currently in production, a (chain)maille coif using the 4-in-1 weave. Here are the resources I used:
Any questions?
Pictures coming soon...
Any questions?
TK - Right now, I'm still cutting my own rings because I don't want to put alot of money into it, in case later I lose interest.
I cut my own rings as well. But rather than using airline snips, I use my Dremel with the fiberglass reinforced cutting disks. Fast and easy.
How do you form the circles so perfectly?
You wrap the wire around a dowel/rod, essentially forming a spring. Slide the spring off the rod, and cut it into rings.
i never tried a dremel for cutting though. do you burn through the cutoff wheels super-fast, or do you use a different bit?
