When you see the Falcon from the outside, that's not the one you ride in. The ride is a totally separate set, and as far as I'm aware it just has a few Falcon corridors, the main hold (where the chess board is) you can sit around in for a while, then you follow the corridors to the cockpit.
When you're looking at it from the outside, it's a completely different build. For one thing it's too small. Like the original movie sets, it's not full size. It's more like 90 - 95% what it should be. You can tell in the Empire Strikes Back when you see Chewie in the cockpit on Hoth. When you look at him from the outside he's just way too big for that cockpit. Likewise there's videos on youtube where Chewie can be seen in the cockpit at Galaxy's Edge events, and it's just the same. You can see he's just way too big. And if you know the details of the inside well enough you can tell by the lights that there's something wrong with the scale in there.
In short the exterior set and the interior sets are two totally separate sets. It has to be this way since technically what you see on screen is an impossible object. There's no way that you can make the two things match, even if you altered the exterior set to be as big as it should be.
So I'm not talking about the ride...
Looks like he failed to read that you understood that they are two different things.When you see the Falcon from the outside, that's not the one you ride in. The ride is a totally separate set, and as far as I'm aware it just has a few Falcon corridors, the main hold (where the chess board is) you can sit around in for a while, then you follow the corridors to the cockpit.
I imagine that inside it probably leads to one of the underground passages that go around beneath the park. There's probably some stairs, or maybe an elevator or something, inside of the Falcon that leads down into the passages. Like has been mentioned, we've seen people inside the cockpit, but they don't go in through the ramp to get there, so there has to be a way to get into the Falcon from the "other side". Most likely they get in through it via these passages.
As Don93 noted, only the Magic Kingdom have tunnels. Trust me with that... I worked at MGM Studios Park (Hollywood Studios today) for many years back in the 1990’s and knew that place inside and out.I imagine that inside it probably leads to one of the underground passages that go around beneath the park. There's probably some stairs, or maybe an elevator or something, inside of the Falcon that leads down into the passages. Like has been mentioned, we've seen people inside the cockpit, but they don't go in through the ramp to get there, so there has to be a way to get into the Falcon from the "other side". Most likely they get in through it via these passages.
Stacks of cash.
OddballFett... he knows that the ride is separate, and he was asking if anyone knows what is in the model falcon outside. Is it empty? Is there hidden gems for executives? Is there an office? An apartment? Storage? Nobody seems to know and he was inquiring if anyone had a clue.
Why exactly can't it match? Would the interiors be too big to fit inside the ship?
