Various OT lightsaber WannaWanga parts (new ALU MPP shroud)
Just thought I’d say “thank you” to Roy for all his hard work in all his products.
This showed up yesterday, and it really does fit a Heiland, as promised!
(Yes, this flash needs everything. The shroud and D-ring are the first conversion parts for it.)
YEP! When My Steel Shroud came, I IMMEDIATELY Put it on and it was like "WOW! THIS was MADE FOR THIS!
Roy's Stuff is BY FAR "THE BEST"!
'Nuff Said!
Roy are there any changes from your last shroud run?
would the only change to the new steel MPP shroud design be the absent step on the inner bore or are there other accuracy changes you've made, just curious?
Exactly. The only change will be that the complete inside will be machined and smooth without step. The outside will be the same. No change there, so my stencil will the same as well.
For those of you in need of a steel shroud for your MPP ... go visit wannawanga ... and here's a sneak peak of parts to come in a galaxy near you :
Chaïm
