propologist
what program are you using for it. If your in illustrator , that green line could GLOW with a good blur....
your my hero Muttley , i love the old graphics. Found my Zaxxon graphic too
my original cabinet has PLENTY of signs of aging, HA! i had no idea that 2.0 had the arcade cabinet... do you happen to have any screenshots?
I could indeed look into doing a run. We just have to agree on dimensions.
Am I seeing things or does the 'Legacy' marquee have a rectangle grid?
I'll see if I can find a shots of the machine (I haven't had the game installed on my computer in a while).my original cabinet has PLENTY of signs of aging, HA! i had no idea that 2.0 had the arcade cabinet... do you happen to have any screenshots?
Yes, I'm using Adobe Illustrator, but bear in mind what you're seeing in the screen capture is how light is hitting the camera lens. The glow you see is due to how the marquee is lit from behind.
This will likely be printed on transparent lexan so you can adjust the glow by light bulb wattage rather than fake the glow in the artwork, which may not may not give the best results.
I am also using CMYK, because that tends to be the color used in the process I'm looking into. The alternative, I suppose, is silk screening. Also, don't forget that most films today are digitally adjusted for color saturation and lighting in post production.
Rik1138- As far as I know, you can print screen in any game.
Cool, yep, that works. I couldn't quickly find a shot of the arcade game except the one I attached. I did find this one online though:
Now that I know where it is, I can get a bigger shot of it if anyone cares...
Turns out these cut scenes aren't video, but are actually rendered real-time by the game engine...
