Since a couple of you seem to like the bead blasted finish I have decided to see if the shop can add this to the process without increasing the cost.
That may sound weird and some of you may be asking “How can they do that for free.”
Well it’s easier to handle a bead blasted part then a part that requires a specific machined finish so it’s a possibility
At this point it would be very difficult to make this an “option” but if there is unanimous consent I can try to work it out
But to do this at the shop level it would have to be done on all of the HOTH flash hides. I’m offering 3 versions and it would be unreasonable to ask the shop to change that to 6 versions.
SO
If you order a HOTH flash Hider and want it bead blasted you need to reply to the group email I sent this morning with a simple YES response
OR
If you hate the bead blast look you need to reply to the group email I sent this morning with a simple NO response.
YOU CAN POST YOUR OPINIONS IN THIS THREAD BUT I NEED THE EMAIL RESPONCE .
Once I have a single NO I will not pursue this on a group level.
Instead it will be added to my menu of inexpensive labor option. I have a bead blast cabinet and can do individual flash hiders for very little money, probably less the $3
The texture will be more fine since my cabinet is not an industrial version but it will look pretty good.
Please respond fast because the shop is cutting these as I type this email.
