Re: Pep to Molded Plastics War Machine,Gatling Gun,Finally mounting the track for gun
Thanks Douglaz and WesR!
Man I thought I'd never be well again!:cry 5 weeks and 2 cycles of antibiotics and I am finally 96% well!!!:confused
Back to work on my armor as well!:love
As I stated, I hated the pepakura back on my war machine...It had a very sad lack of detail, so I cut it out! Here is the back sans center section. I am also experimenting with sculpting some clay to get special details...not happy, but for a first attempt, ill not complain too much.:unsure
Today I cut some pvc plastic sheet 1/4 inch and using my heat gun, I bent and formed the sheet to perfect shape for mounting to the back! I did mold and pour a nice flat rondo lip to recieve the back plate... the epoxy riveted it into place and the back is now as firm or firmer than it was.
Here is how it looks from the other side.
I am also using the PVC sheet to bring in some of the armor details that needed to be raised and sharp..if you look to the lower left tip you can see some of the detail. I'll go into more on that later, with more close ups.
Now that I have a clean, flat, secure base to attach it too here is the long awaited track system that will eventually hold the inside part of the mini gun armature!!
This is a track with about 100 bearings and a flexible inner track that even with the curve put into it allows the track to move from left to right like butter! I hated the idea of the mini gun always being stuck on one side. I am sure Mk1 will be simply moved by my helper at my first con, but as time passes I will get it more sophisticated.:cool
The minigun armature will come in through a slit in the top rear of the armor to attach to the mountng plate.
:love
There still are some mods I need to make to the track, but I am very happy with the way it fits and moves!:$
The final out come will hopefully be a fully Arduino controled minigun, but more than likely the early test phase will be an external R/C system using my old 12 channel R/C radio and a helper that stands off a little, sort of like they do with the R2D2s at comicon.
I might try to recruit Ryan aka therealstark to give me lots of input!! :confused The man is truly a genius!
I want the gun to move right shoulder to left and back as well and up and down and a fully active pivot on the gun itself!:cool
A big shout out to my very very good friend David aka Propnoob74 who is also building a War Machine and helping me with mine in too many ways to list! I wish you were here Mi Amigo!
Got your Corona right here and ready to celebrate the Holidays!:cheers
