bcstanding
I'm finally at the point where I'm declaring both my ST3 PII phasers ready to paint!
thumbsup I've got everything I need except for an idea of how you prop builders hold the piece you are painting so that you can paint the entire piece and then set it down to dry - when the piece can't lay flat but needs to be suspended in the air somehow. For example, on a ST3 PII, the part of the phaser where the PI sits has a hollowed out part that isn't visible when the PI is attached. I need to somehow figure out how to hold the phaser by only touching that hollow part, then paint the entire phaser, and then somehow set it down on something that will keep the phaser off of the table AND have it be stable enough that the phaser doesn't fall over. I don't know how well I'm explaining this, but hopefully you experienced propmakers will understand what I'm getting at. The only other thing I can think of is to paint one side, let it dry, and then paint the other side, but I know I've read somewhere on prop boards that you should paint the whole thing if it's at all possible. I'm planning on painting them both in the garage and then bringing them inside to dry since the temps are getting pretty cold at night here in Utah. I'd appreciate any insight any of you have to offer. Thanks for the help!
