Seeking help to model an odd piece
tuc
Hi,
Just found this, hopefully people who actually know what they're doing might be able to make some suggestions (I'll understand) to do this.
I have a grid of buttons that belong in a TV remote (OMOTE/CAD/Button Grid.stl at main · CoretechR/OMOTE) . Trying to get this printed properly, we only have 1 option, FDM. We'd like to be able to use other materials and still get the definition/etc. When printed, it looks like -
It starts to get a bit wonky because of the "connector" pieces (That are necessary, keeps the parts from rotating/moving/etc) . It looks like -
and
I've tried a few different ways to cast it
1) Create a base of only casting material and let it full dry (I'm using Smooth-On Mold Star 15 SLOW Platinum Silicone Rubber in all these examples). I spray a release on the base, place the button matrix, spray it all again and put another layer of casting material. Since the item isn't very rigid/heavy the casting material gets underneath and it's unusable
2) I again create the base. I then mix up a tiny batch of casting material, and with a paintbrush try to paint around the edges of all the items, put the item down, and place a weight on it. Once fully dry, spray it all and cast the rest. I've yet to be able to have this come out 100% correct.
3) I again create the base. I then mix up a tiny batch of casting material, but pour enough so there is just a sheen ( there should be a 1/2 covering of the bottom lip), weight it and let it dry. That looks like -
(The slots on both sides are for being able to match top and bottom. I didn't quite get it to not go over the connectors/etc, so I cut it away carefully with a knife. It was good enough. I then placed the matrix in position and weighted it for a day. (Connectors will break if I personhandle it at all). I poured the casting material on it and went to sleep. Next morning, the grid floated to the top. I had to cut it out of it's tomb.
At this point, I don't know what else to do. Please question/comment, everything will help.
Thanks!
Tuc
Tuc, Not being a smart a**, but what are you trying to accomplish. Old remotes are plentiful. Why not just source some and scavenge the buttons for your project.
I don't quite understand the problem. Is it the material? Is it fdm printing? You can print on a fine mesh cloth with an fdm printer and have the buttons connected that way with no risk of fatigue making them break away from each other. Just search for printing on mesh fabric. You could also print the symbols in a different colour with any good slicer with no need for special hardware. That is is also covered elsewhere on the web.
