Serafino
So there's a blob on the frag bevel ring in the Mechanismo and recent LFL pics, and Gav agrees with Roman that it means there are notches in the top ring of the prop grenade.
I think this is a misreading of the evidence for the following reasons.
In the Chronicles 'transistor' photo, an unbroken edge highlight is clearly visible in an area where a 'notch' would appear.
In the Mechanismo photo:
A second area (circled) where a notch would appear does not show one. Admittedly the resolution is not enough to be conclusive either way in this area, so call that a wash.
The 'blob' (short lines) is not aligned with the edges of the cut leading up to it (long lines), and shows no signs of depth. It is 'some' evidence for 'a' notch, but not even conclusive for that much, let alone for notches all the way around.
The LFL pic does show an apparent notch with a shadow which is dark enough to imply depth, but if it is the same one as in the Mechanismo pic it is in the wrong place. It may be a result of later damage rather than a cutter mark.
So there is clear evidence for one area with definitely NO notch, and questionable evidence for one area with maybe 'one' cutter notch. I don't see how that leads to the conclusion that the frag bevel ring is notched.
