Originally posted by darthscifi+Jul 11 2005, 02:42 PM--><div class='quotetop'>QUOTE(darthscifi @ Jul 11 2005, 02:42 PM)</div>
<!--QuoteBegin-incrediPAUL
@Jul 11 2005, 09:12 AM
You could start with an oil base non hardening clay, and cast it with plaster. Also, There are many polymer clays (sculpey III, super sculpey) you could use that are heat cured in household ovens, very handy. I reccomend the later.
[snapback]1031022[/snapback]
I second the sculpey. I use supersculpy and its great because you can work in layers. You can do part of the sculpt then bake it and add more to it later. It helps when you have a sculpt that may be off ballance or there is a chance you could mess up something you worked on already.
[snapback]1031040[/snapback]
[/b]
