Re: Iron Man Build
So, I'm trying to get the back to look more movie accurate and do the spine, etc. I tried cutting some of the thicker foam (leftovers of some interlocking 10-12mm thick stuff I used to build a pig castle for our guinea pigs...makes for a great surface for them to run on and cuts back on bedding that has to be changed because they don't poop or pee on the foam...) for the little circular piece at the top of the spine, and couldn't get it round enough, even enough, or smooth enough, so instead I cut a piece of wood the right shape, drilled a hole in the middle and sanded it. I also designed templates for the spine and the curved portion between the circular piece and the spine "discs." After I cut the spine out, I tried burning/melting the edges with a soldering iron. It just made the edges fuzzy and crispy. So, I cut another spine section and used curved nail scissors to take the sharp edges off--that's the first red foam pic. Regular scissors were both too big straight to get in those teeny spots I cut out, but the nail scissors worked great. Then I used the barrel of the soldering iron to smooth those edges. Not perfect, but I think it will do the job--second red foam pic.
You can see the difference between the two spine pieces I did with straight burning on the edges versus trimming, then burning...much smoother when I trimmed first, I guess because there wasn't as much foam that needed to be "melted" away. Now I need to figure out how to attach the disc portion to the back of the abs piece. Not sure if I want to separate the last couple of discs and just attach them to the abs section so they will move (my abs are connected with elastic...testing out how that works still).
