TryChick
Re: Iron Man Build
Wow. Done sanding for the most part. I put on a coat of primer, sanded with 400 grit and put on another coat. Got a little carried away and have a drip or two I have to sand out :unsure
Also got a few more magnets glued on. Had to add some bondo to the back inside of the main part of the helmet so the magnets would be flush with the ones on the bottom piece.
Still debating on whether or not to keep the original teeth. They cleaned up OK, but they aren't perfect. And still have to finish up the ear pieces. Am going to try boochieboy's hardboard ears since I have a scroll saw and router to work them...can't hurt to make the attempt since the pepped ones I have are a bit warped.
