Interest Luke ROTJ V3 Emitter (mini run)
DaveP
Hi everyone.
You may have seen that I recently converted one of my V2 kits in to a V3: Luke ROTJ V2 -V3 conversion
Well, the time has come to add the emitter! The kit that I made this from was without one anyway, but the V3 and V2 emitters are quite noticeably different...
I was surprised to find that the face plate is not "that" much bigger than the V2 (although it is slightly). It looks much bigger though, due to it having a smaller bearing housing. The first step after the face is also smaller, giving it the impression of having a large emitter face. So overall, it is quite distinctive when compared with that of the V2:
I've used this little mini run to test the waters with some local machinists in preparation for my Static Obi run. After the delays of last year, that were brought about by the pandemic, and the problems we're seeing with re-casting, It's been my hope to find local machinists/manufacturers to work with going forward...
The first few quotes that came in were a bit of a shock to be honest, and did have me wondering if I'd have to abandon the idea and stick with my previous supplier.
One has come in now though, which isn't too much higher than that quoted by my overseas manufacturer, and hopefully it sounds acceptable to anyone wishing to jump in on this little run. I think prices have increased generally due to the pandemic too so I guess we are where we are.
This is purely a personal project for myself, but figured I'd check to see if anyone else wanted to jump on to bring down the cost. To have a one off made, it's somewhere in the region of £140, so getting a few more people on board makes a big difference.
**EDIT (lower price)**
I have managed to negotiate a revised X10 price for this, which will be £38 each plus shipping. This is inclusive of UK tax (20%) and PayPal fees (5%).
I negotiated this price on the basis that I have another, much larger project heading their way. Apart from rounding up to the nearest £, there is ZERO profit added to this and I will, of course, be paying for my own.
Shipping:
  • UK = £5 Royal Mail Signed for 2nd class (insured up to £50) 3 day delivery aim.
  • International = £20 International Tracked (insured up to £50) 5 to 7 working days delivery aim.
I will need to take upfront payment for the actual emitter, followed by the shipping payment once the parts are finished. I've quoted for 20 day/4weeks, which isn't the fastest available, but has brought down the price slightly.
It will fit other V2/V3 kits though, and could obviously be used on custom builds, so hopefully (fingers crossed), we can at least hit the 10+ mark.
Anyway, please let me know if you'd like to be included in the interest list.
Thanks for looking.
All the best, and MTFBWY,
Dave
Interest List:
  1. DaveP
  2. BRRogers
  3. Nailuj
  4. .
  5. .
  6. .
  7. .
  8. .
  9. .
  10. .
Would you offer finished commissions for the whole V3? Sign me up for that if so.
Hey Daniel. I'm afraid not. Not at the moment at least. I'm completely out of parts now for the V2s and this is just a quick personal project that I'm squeezing in between runs in my spare time. I really just need one for myself but figured there might be some interest from a handful of people wanting to do a similar V2-V3 conversion like the one I just did, if they happen to have a spare V2 kit lying around. :lol: It was a fun build, but I'm not really taking on commissions right now as I'm really busy preparing the Obi Wan run. I figured this would be a good opportunity for pricing up local machine shops for that run too. Sorry for any disappointment. I'd definitely consider it when I'm not quite so busy with other commitments (y)
Dave, not sure what FX hilts you might have seen or worked on if at all; do you think this is designed in such a way it could be a conversion part as well for the likes of other V2 style FX hilts out there? Assuming the end user may just need a threaded rod or the like?
(Interested, as I’m working on converting my Solos Hold V2^2 into a V3 in a similar manner)
Hey Bryan.
I haven't really designed it with FX in mind to be honest. It would need a fair bit of modification. It's designed to have a clean break at the neck and to fix on to the rod.
The rod for the V3 wasn't as thick as the 8mm one in the V2, so I'm going to add a bushing to the neck of my V2 body.
The bearing housing is pretty shallow too (and narrow)! Not ideal for a blade.
If you were wanting to make an FX V3, I'd say stick with your SH emitter and modify that to make the emitter face look wider (by shrinking down the step directly after it). If it isn't already dented that is.
If you're wanting a static though and wanted to use one of these, it would just be a case of adding something at the neck to allow for a 6mm rod. (y)
It's not looking likely that it's going to get to 25X unfortunately, but there's a chance it'll get to 10X maybe at the higher price of £50.
Would you be interested? We'd just need to find 8 more people! :lol:
Perhaps others looking to make a SH v3 static conversion could be tempted if an adapter was sorted (with little to no inconveniences for you I imagine) I’ll take a look
I'm not sure what the ID is on the Solos Hold. I left plenty (too much?) clearance on mine for the motorised stunt, so it needed a bushing anyway on the V2. I'll just be pushing a flanged bushing in to the neck (from the inside) and securing the rod inside with a collar. I'll drill through the bush so that the set screw in the wind vane can make contact with the rod too, to stop it sliding back in before the emitter is attached. Then the emitter will just fix to the rod with its own set screw. I guess the bushing will depend on the kit being used.
I think I have an idea… 6mm is quite close to 1/4” … enough so that it wouldn’t be too difficult to drill the emitter (or look so different)
I can basically get a linear rod and bolt it inside with a typical imperial setup and a shaft bearing sleeve inside the top of the (lower) windvane. The rest should work quite swimmingly
Sure Dave, put me down.
I figured out my setup using a 1/4” partially threaded bolt, so I’ll just drill the center to size ;)
Dave, will the set screw holes be pre-tapped? Set screws included? I’m fine to do that if need be… Just curious :)
That's awesome!
Thanks Bryan. :)
The hole will be tapped and include the set screw. (y) Looks a little small on the model. That's because its modelled to the tap size (4.2mm) It'll actually be an M5 thread (y)
Fingers crossed we can get another X8 at the lower price.
include me please
I'm sorry guys,
There just wasn't enough interest in this unfortunately, so it won't be going ahead now. I ended up having to get a one off made for myself as it didn't look likely to reach the X10 needed.
Might you consider producing these together with the 40th anniversary hero run? Since it will be possible to do the other control boxes, I’d imagine it’s the best chance to get enough interest. I’m hoping I can manage to get 1 of each config, and a more accurate emitter is always good.
Thanks for the message. Parts for the Hero run are already in production and will include the Hero/Yuma/ISYHCANL. Further down the line (most likely towards the end of the year), I'll be ordering a limited number of V2/V3 parts. (y) Hope that's ok.
