Let's Talk All Things 3d for prop creation, Scan, Design, Sculpt (real and digital), Print and Finish
Copying in from another thread:
greenmachines said:
What is the spot putty? and yes, will be copying your comment into several 3d print convos
mattycsi said:
A standard spot putty, bondo/3m, any of those. Mix a blob in a glass jar with a lid with a few drips of acetone and shake up until it disolves. Doesnt take much acetone, so go careful when experimenting.
Then brush on, I do 2 coats. You won't need drying time between coats. Give it about 20 -30 mins to dry then buff smooth with 320 or 400g. Sands really easy, like, no effort.
I'm building a proton pack for cosplay, was perusing this vid, when the guy drops this technique, I ran, didn't walk, into my workshop!
About 5:20 is the bit you
need.
need.
Make sure its not the waterbased putty/filler as it wont mix with Acetone.
So, this might seem a tangent again but this idea that acetone will work here, somehow reminded me of finding out that pla is plant based plastic.....AND..... it has a very short lifespan. Has anyone had experience, first hand, with pla props decaying? Being therpf I think this might be a very VERY important topic. What lifespan is really achievable or maybe this pla warning is overblown and we have decades? I speak from newb view, so, anyone have input, a work around, a better substance, or even just a horror story?
I am just super stoked there might be an additive answer to smoothing instead of only negative (sanding etc.) besides the filler paint version. I still haven't purchased the filler primer so I really should do that before going any further. If it works it works. Cart before the horse is my go-to plan most days and I punish myself for leaping ahead but this acetone mix sounds really straightforward. Especially if I can see the results fast enough to know to add another coat or stop and high grit sand.
Its Amazingly simply to use you should be fine.
Being otherside of the pond some materials can differ and ours are pretty much all waterbased but still work but not with the Acetone. I just did another wash last night on my Xwing helmet and now it just needs wet n dry sandpaper but I honestly cant see any layer lines then again it was pretty smooth to start with.
The only big difference I can see is the Acetone makes the layers dry quicker I dont think there is any chemical bond but I could be wrong. The filler I used this morning has set like cement.
My goal of smooth and realistic has yet to come into my skillset so more practice is in my future.
I shyed away from and still have to finish so many builds from a Martian War Machine to a Boba Fett Jetpack but the Xwing helmet has so far but nothing but a joy with this filler method.
I think so far ive spent maybe two hours max on it and sure helps being large surfaces to work on.
Its getting warm here by the beach so I might do a bit more later..
