How wide are those leg thingamys? (wow, my english, huh?) I just haven't got wide forearms at all, and skinny wrists, and so don't want to buy something and be like "*********"
Well the width of the very top of the leg is 16 which is the same as my wife's leg (she didn't like me coming at her with the tape measure) and with her leg As reference it should be more than wide enough to fit around my forearm and the thigh part my bicep
With respect to the transparent worbla problems - would it be worth doing it in pieces, then trying to join it in spots where it will look less obvious with adhesive, or an adaptation of the original costume and add screws to give the idea of it?
That's what I'm doing. For the bracers, biceps, and back it isn't really needed since those are just simple curves. For the shoulders and chest though, I'm going to pattern them out, shape individual pieces, then glue them back together. While welding isn't entirely possible, hitting a seam with a lot of heat for around 45 seconds will somewhat join it together. I'm just smearing some E 6000 on the inside of the armor to make sure it won't separate. For the shoulders, I made two cuts. One at the top, one at the bottom. The seam line goes straight down the middle. For the chest, I'm going to try and make the seam lines around each muscle so the paint/shading will cover it up.
How much did you order? I am looking at ordering some this week or next and start having a play with it, start with some simpler pieces and going from there. How hot does it need to get? Will my hair dryer work, or should I steal something out of the boyfriends shed to heat it up?
I feel like I need to make sketches of what I want to do so that I'm not just fumbling in the dark with this.
I ordered three jumbo sheets with the intent of either storing what I didn't use or selling it to a friend (maybe an enemy with how rough it is to use) The first sheet has made two bracers, two shoulders, and the chest. It'll probably be enough for the biceps as well. Back will be another sheet. Granted I've also messed up two shoulder pieces and used a 12x15 piece for learning on.
A hair dryer definitely won't get the job done in a timely manner. Steal something from the boyfriend's shed.
Definitely make sketches and paper patterns first to see how they sit on you. I'm lucky my partner is able to do that part for me, otherwise I'd definitely be fumbling in the dark.
I think this is the answer. Separate pieces joined by glue. Online sources recommend super glue but I like the idea of E 6000, if it stays transparent. It will definitely be more flexible. Apparently, heat gun in one hand and wet sponge in the other is the way to go.
