IM MK VI Build Question....
DOORMANMATT
Ok I'll be embarking this wk end on my first foam build of said suit, so far I have ordered:
1 x xacto angle foam mat cutter
1 x hot glue gun
1 x heat gun
2 x 8mm foam camping mats
I have the Robo / Stealth templates and am good to go!
My question is... What am I missing if anything and whats best PVA, Plastidip or both? And is Plastidip spray better than brush on?
Let me know please guys?
Cheers
Matt
you can use pva first and plastidip on top of it
spray is better because you dont get brushmarks, which means a cleaner surface
you can get a hot wire cutter, if you want to spend the money
also you might need some thinner foam for detailing
Cheers EyeofSauron it's appreciated!
I'll get some thinner foam. What mm would u suggest?
Haven't researched the hot wire cutter, I'll have a look!
Thanks again!
i havent built anything in foam yet, but from looking at different builds, i see they use normal craft foam sheets which are 2 mm or something in that vacinity. im researching myself to start a foam build, but theres hardly any 8mm foam here, or foam at all for that matter
