Lusidous
Greeting and Salutations
So this is my very first build ever
I Have -10 skill with a glue gun as far as a build for Costume but I though I give it a shot anyway and hear what the verdict is. So i jumped in feet first (no really)
Using JFcustom Guyver Foam at once Pep (http://www.therpf.com/f24/guyver-148353/)
I went out and got 2 eva foam beach mats From Sports Authority
One side of the mat has a very smooth feel while the other has more of a Small rigged side. So used smooth side to put masks on.
Using a glue called Scotch Clear Stick
Was able to make mask stick to foam for better pattern.... clean up was easy cause glue is like past wipes up with paper towel glue other side and your good to go (if your towel starts sticking to mask your using to much) but masks will not move here a pic of me holding it up to the wall
So Got my patterns laid out and got to cutting and gluing
here a quick pic of what I was working with
Close ups of my first piece a heel
Now I know this is the foam at once and is made for fast builds but i took my time cause I'm a first timer
but was still able to build left and right foot
I was a little scared cause it seemed rather big and then looking around is see that most wear shoes when they are in armor so I tried a test fit of the left foot
Put on my converse all stars and then for more effect and idea flowing pulled tube sock over shoe
and my day was over
but today is a new day so I should have one if not both lower cafes today
I'll do my best to update as so
also wanted to thank JFcustom for info
and my day was over
