DEAD SPACE Isaac Clarke Level 3 Suit SKS Props
SKS Props
Ok, so I finished my Isaac Clarke DEAD SPACE helmet. This is level 3 helmet from the first game you can find the build here http://www.therpf.com/f24/dead-space-helmet-lights-installed-201960/
Now I am starting the rest of the Level 3 suit. I figured the back rig will be the next most difficult part of the build, so here we go. The rigs base will be styrene and I will probably cover most of this with craft foam, but we shall see.
Materials:
Head Form from CFX
Monster Clay [url]http://amzn.to/2mIaecs [/URL]
Smooth-On Rebound 25 [url]http://amzn.to/2mIaecs [/URL]
Smooth-Cast 65D [url]http://amzn.to/2mIaecs [/URL]
Plasti Paste [url]http://amzn.to/2mIaecs [/URL]
EVA foam 1/2" and 1/4" [url]http://amzn.to/2mIaecs [/URL]
Craft foam 1mm-3mm [url]http://amzn.to/2mIaecs [/URL]
Barge [url]http://amzn.to/2nn2ycQ [/URL]
Loctite Super Glue [url]http://amzn.to/2nn2ycQ [/URL]
Styrene Rods and Sheets [url]http://amzn.to/2nn2ycQ [/URL] [url]http://amzn.to/2nn2ycQ [/URL]
Rattle can Primmer and Colors [url]http://amzn.to/2nn2ycQ [/URL] [url]http://amzn.to/2nn2ycQ [/URL]
Liquitex Heavy Body Acrylics [url]http://amzn.to/2nn2ycQ [/URL]
Green LEDs and Coin Ballery holder - 2032 battery [url]http://amzn.to/2nn2ycQ [/URL]
Plasti Dip Rattle Can [url]http://amzn.to/2nn2ycQ [/URL]
Upholstery fabric [url]http://amzn.to/2nn2ycQ [/URL]
Painters Tape [url]http://amzn.to/2nn2ycQ [/URL]
Re: DEAD SPACE Issac Clarke Level 3 Suit
Brilliant keep up the awesome work!
Are you building that out of foam mount board by any chance?
Started to assemble the bit and pieces that will make up the back rig. The styrene was heated and formed to fit my back and shoulders.
Dude that is going to be sick when it's done, kudos.
Check out iron patina when your ready to weather it, great stuff when you need rust as it's the real deal :thumbsup
Thanks man I will check it out
Re: DEAD SPACE Issac Clarke Level 3 Suit - Rig Mock up
WOW this is really coming along nicely and as an avid Dead Space fan you get my sub for this build.
damn this build is looking intense. is that 20mm conduit heat bent with the styrene mounted to it?
It's all styrene right now. But I will be going back in and adding foam to bulk up the underside and create some extra details.
The build is looking great keep it up caint wait to see it finished.
WOW o_0 Love it so far.....
Thanks guys that means a lot and pushes me to create even more!
Loving the detail! Once you get the foam to bulk it out, will the parts move enough to be comfortable once the ribs are on?
Thanks!
The rig is actually in 3 different pieces held together with elastic. So it should be able to flex even with a bit more detail on there. The ribs are also going to be held in place with elastic and will be made out of mat foam and will be heat formed so they can wrap around my mid section.
WOW!!! SoOo detailed!! Just checked out your helmet build also...bada bup bup paaaa..."I'M LOVIN' IT!!" Can't wait to you see you complete it. How many hours out of the day to work on this badboy?
