To answer the question about the battery compartment, you remove one of the "lenses" on the face of the battery, and somewhere inside, there's a small white box that houses 3 AAA batteries. Don't know where they hid it, 'cuz with the battery lit up, it's very hard to see where the battery box would be blocking the light shining through the body of the prop. But it's in there somewhere. Removing the "lens" on the face of the power battery prop requires a small Allen key... I believe a 1/16th size.
When the battery is open, you would presumably have access to the LED light source, but as you can see in the pictures, they've put some kind of paper or fabric in there surrounding the light source, to simulate the look of the "ribbons" of emerald energy seen within the battery in the movie. You would presumably have to move that out of the way to access the light source and I'm assuming it would be a pain in the butt to put that stuff back in the right way. The lantern is nice and bright, so I'd just leave it alone.
The ring that's included is made of PVC, as are the rings included with most of the Power Battery Prop Replicas. This makes the decision to make it a size 14 even MORE baffling. It should have been set to a more normal size, say a 9 or 10, because then the PVC band would flex to fit larger fingers. But to wear this size 14 monstrosity, you'll have to find a way to make it smaller, with some kind of ring sizer... unless you wear it over a pair of gloves.
My only complaint other than the size of the ring is a complaint I have with ALL the recent Power Battery Prop Replicas, not just the movie one. It also applies to the Sinestro Corps Power Battery Prop Replica and the JLA Trophy Room Metal Power Battery Prop Replica... I don't like the way they changed the on/off switch modes.
I have the ORIGINAL GL Power Battery Prop Replica from 2000. On that Power Battery, "off" means the light is only activated by touching the included magnetized ring to the magnetic activation switch, activating the light for 30 seconds. "On" means the lantern is CONTINUOUSLY LIT. I like that a lot!
thumbsup
Compare that to the newer models.... where "off" means COMPLETELY OFF, will not light AT ALL, and "on" means that the light only comes on when you touch the ring to the face, and it only stays on for 30 seconds. I DON'T LIKE THAT. But what can you do? That's the way DC Direct chose to make the newer ones.
In other news, my Movie Power Battery Prop Replica is # 38 out of 2500... 38... the exact age I was when the movie opened in theaters!
I would have preferred either # 17 (Jack T. Chance was the GL of Space Sector 0017) or # 42 (if you don't know the significance of that number, you're not yet enough of a geek!
) but 38 definitely works! Definitely the lowest serial number I've ever received on a DC Direct prop replica!
thumbsup
