A couple of other possibilities:
Instrument rating required
Use the Force edition
Turned out that it was extremely difficult to get dogs trained to fly a Y-Wing, no time for instrument rating certification, and the only pilot that was capable of using the force to navigate already has an X-Wing. So, the front windscreen was opened up for regular already trained Y-Wing pilots to view what is in front of them.
Here is the final design result, unless there are tweak suggestions from anyone. Given the compromises that needed to be made to fit the model and still capture the look and feel I think this came out great.
View attachment 1454233 View attachment 1454232 View attachment 1454231 View attachment 1454230
For FDM printing a 0.3mm nozzle is required. Supports will be needed. This should print beautifully with SLA.
Daaaaaang... Can't you buy a studio scale kit for that much? Or close to it? I have two 1/48 Y's all printed up and sitting in a box that I just need to finish.
SB
Big thanks to Hagoth for the canopy sculpt! If anyone here is interested in a kit of this model in this scale (c'mon Bandai!!!!), I have a Limited Run thread setup in the project runs thread, located here: Limited Run - 1/48 Y-Wing Kit (SLA resin printed)
SB
I wrapped some gaffers tape around the end of some needle nose pliers (so they wouldn't dent the brass) and just bent the pipes around that. Mine definitely aren't perfect, but I only spent a couple days doing it. Just look at the Bandai instruction sheet that I linked in my sales thread (or if you happen to have a Bandai Y laying around, use that one). Please post progress photos!Hey Steven, how did you bend the brass rod, for the pipes?
Thanks! I definitely have a Bandai kit or 2 lying around. I put all the parts from the Bibby-Bills kit in a FM Y-Wing box. Hopefully it won't stay there too long.I wrapped some gaffers tape around the end of some needle nose pliers (so they wouldn't dent the brass) and just bent the pipes around that. Mine definitely aren't perfect, but I only spent a couple days doing it. Just look at the Bandai instruction sheet that I linked in my sales thread (or if you happen to have a Bandai Y laying around, use that one). Please post progress photos!
SB
Thank you! You're most kind.Took a look at this again on my desktop screen, it looks fab! That brass piping! Impressive. Now I really want another Y-wing to play with, this was an inspiring thread.
