rosskow
Re: pepafett (boba fett helmet pepakura attempt) Ventilating
i've got some milliput but still yet to understand the material so dont use it all that much and i guess i just like to make work hard for myself solely using standard filler
think i'll be working with something a bit easier now, wood/MDF to make the ears so that should be a nice change of pace.
who45 - thanks for the comments and suggests
long work there, and ive seen the cheek done a few times........... bit late now but i use milliput if i need to shape - a 2 part putty and when its dry it sets rock hard and is sandable. but the beauty of milliput is that you can shape it and if you wet your fingers and shape it you can smooth it out, very much like working with clay but its an epoxy so sticks to anything
i know its a bit late now but for the future use milliput if you need some shaping done - you have a good hour before things start the hardening process and after 14hrs or so it sets rock hard. it will certainly allow you to mold and shape the cheek first time, then add the filler or some more milliput to finish the bits off - i pay 2.50 a box for mine altho hobbycraft charge around 5 quid
good to see it IS taking shape now tho - the hard graft is starting to pay off
