Arkham Asylum Armored bust with custom base concept...
Here's another small update. I decided to cut some metal for the based to give it some strength in order to hold up the cowl as it gets heftier. I took a side panel from a scraped computer chassis and used part of the base as a stencil. Also I resined/bondoed the rounded base portion but it needs alotta work.
Oh my god !!! How can i have missed this thread ? Amazing... Subscribed !!! Do you plan on doing a run or release the files in the future ? :thumbsup
Sorry this is as late as it is, but here's a small up date on the model, got the chin finished, then realized there was a really small piece I lost somehow in the process so I need to re-print, cut, and attach that one. Otherwise the main model just needs minor tweaks. The base and eye portions should be following shortly!
It boggles my mind knowing this stuff can be done with paper! If I only had the time and patience...
Admittedly patience is needed. I did a small grenade (Halo) and luckily had a few materials lying around. Still took me an hour or so of cutting and bending and sticking.
Very enjoyable though!
Thanks! This model really put my patience to the test but meh it's almost done, or at least for the cutting/folding/gluing part. I should have another update this evening for everybody.
Just a quick update, I finished etching out the first steel reinforced base part as you can see in the images attached. Still a lot to do...
